Re: Stage 1 Re-map
Mr Footlong
Re: Re: Stage 1 Re-map
Post by Mr Footlong » Fri May 17, 2013 5:50 pm
http://www.rs6.com/showthread.php/22688 ... utting-out
I had to have a N75 valve replaced on when/after being tuned as it turned out to be a weak link and died so could be a potential problem as mentioned in a few threads I have read, amongst other things. With these cars there is soooooo little room to inspect everything really close up prior to mapping that it isn't uncommon for these niggles to pop up post-map running with regard to vacuum hoses etc.
Again, I am not saying what I have said is right as I am far from the most technical on here!
Current:
Gone:
captrs6
Re: Stage 1 Re-map
Post by captrs6 » Fri May 17, 2013 6:14 pm
Thanks Footlong.
Just gave it a good going over there...reached 130 light years and was still pulling like a train.
We have just rescanned and the only issues are:
18058 - Power train data bus......Missing message
18325 - Coolant relay....
Rolling test 3rd gear at 50mph pick up versus Z4 - pick up and acceleration was fast, responsive and seemed more 'urgent'.
Capt
2003 C5 RS6 - Stage 1 Re-map, KW Coilover Kit.
The C5 is the S&M of car ownership - "Pleasure and pain".
Re: Stage 1 Re-map
Post by Shoppinit » Fri May 17, 2013 6:27 pm
grizz wrote:Hi Guys , the car has a viper stage 1 map not a revo stage 1 .
The car was tested before and after and was makeing the correct boost .
Please call us if your still unsure .
grizz
Same map as me. It's a good one. I can post dyno and 30-80 times if you want to compare.
Re: Stage 1 Re-map
Post by Shoppinit » Fri May 17, 2013 6:30 pm
captrs6 wrote: 17963 - Charge Pressure
P1555 - 001 - Maximum Limit Exceeded
Oh, just spotted this. You need a new N75.
captrs6
Re: Stage 1 Re-map
Post by captrs6 » Fri May 17, 2013 6:35 pm
Hi Shop
Can was taken for a wee drive - a few notches above the limit. We have since rescanned and the code has not popped up.
Capt.
Post by Shoppinit » Fri May 17, 2013 6:40 pm
The fault must have happened since the map since no way grizz would have left old fault codes. It didn't happen on your wee drive, but it probably will again. That's the thing with electrically operated valves.
If your N75 is faulty then you could be getting less or more (as in that fault code) than you should. Or both. But not simultaneously, obviously.
captrs6
Re: Stage 1 Re-map
Post by captrs6 » Fri May 17, 2013 7:10 pm
I will drive it for a few days and then re-scan it.
grizz
Post by grizz » Fri May 17, 2013 7:15 pm
Sounds like the n75 is on it's last legs ..
Unit 20
0151 3366888
captrs6
Re: Stage 1 Re-map
Post by captrs6 » Fri May 17, 2013 7:43 pm
How much is the N75 to replace and how easy if this is the issue?
captrs6
Re: Stage 1 Re-map
Post by captrs6 » Fri May 17, 2013 7:44 pm
Hi Shop - can you post the map results please? :beerchug:
Mr Footlong
Post by Mr Footlong » Fri May 17, 2013 7:59 pm
N75 isn't really sheap if memory serves but more often than not, these cars will need at least on in their lifetime. As with so many of the electronic bits on these, the good old intermittent fault pops up but in the case of a suspected N75 on its way out, you honestly are best getting it done.
Grizz, if you are on, quick sidetrack, did those guys drop the seats off to go in to Lee's car? Thanks.
Current:
Gone:
captrs6
Re: Stage 1 Re-map
Post by captrs6 » Fri May 17, 2013 8:06 pm
Is it easy to replace?
sweegie
Post by sweegie » Fri May 17, 2013 8:22 pm
£60 should see you for the part. It's at the back of the engine though, under the airbox, so a little inconvenient to change.
http://forum.rs246.com/viewtopic.php?f=2&t=81381
PS: the part you need is 078 906 283 B
Recycling dinosaurs for fun
Re: Stage 1 Re-map
Post by chunky79 » Fri May 17, 2013 8:34 pm
Doug spotted mine was faulty at the rolling road day, torque was stupidly high. Part cost £50 and Chris changed it in 6 mins. Worth checking all hoses whilst doing it. Sure Shopp has posted a pic at some point with them labeled.
Edit, Sweegie has put a link to the pic, good man.
captrs6
Post by captrs6 » Fri May 17, 2013 8:52 pm
thanks guys. I will run the car and see if any further erros pop up.
If it does, or I notice symptoms I will replace the part. .
Sweegie - thanks for the link mate
Users browsing this forum: Google [Bot], Quinten, srichards and 66 guests
