Health check at mrc 309bhp vac issues and decoke
ArthurPE
Re: Health check at mrc 309bhp vac issues and decoke
Post by ArthurPE » Wed May 15, 2013 3:35 pm
Amar wrote:I know the difference between wheel/crank outputs, and how the dyno works out crank power. However, as manufactures don’t issue WHP figures, they mean feck all to me; wheel horsepower is a bit too geeky/techy for me. My comment wasn’t intended to be rude by the way, maybe I should have used a smiley or two.
a dyno will not give absolute numbers, only comparative ones, so comparing derived dyno fw numbers to factory ones made on a engine stand is useless
so in order to make comparative evaluations (as is the case here, before and after repairs/cleaning) the wheel numbers should be used in order to remove as many variables as possible from the equation
to easy to manipulate numbers when using 'correction factors'
there are chassis dynos that measure losses
Mr V10
Post by Mr V10 » Wed May 15, 2013 3:45 pm
Silas wrote:No come back from that answer, ouch!!!
Sheeesh, so so serious. Like I said, I didn't mean to cause offence or work anyone up.
So, what do you guys do for fun around here?
*tip toes back to RS 6 fourm(s)*
RIV
Post by RIV » Wed May 15, 2013 3:50 pm
No offence to me what so ever, the reply just made me laugh :beerchug:
ArthurPE
Post by ArthurPE » Wed May 15, 2013 3:54 pm
I don't think anyone is worked or of offended, just trying to clarify the technicalities involved
although a converted fw number may have a dumbed down feel good factor it has no engineering/technical value
it's for the consumer, not the technician, and most consumers are poorly informed
Mr V10
Post by Mr V10 » Wed May 15, 2013 3:58 pm
:thumbs:
Noyjatat
Post by Noyjatat » Wed May 15, 2013 5:39 pm
I have no idea what horsepower my car has got at either the flywheel or the wheels but I smile everytime I put my foot down, that's enough for me.
Saying that though it will be going to MRC for a clean and remap shortly as I would like to move it back towards its original feel. Been working hard on it to make it like new again inside and out and nearly there. Put in some personal touches just to make it feel like something special to me and enjoy seeing what new things people have done on here after all we all love our cars :D
scaghead
Post by scaghead » Wed May 15, 2013 6:17 pm
Noyjatat wrote:I have no idea what horsepower my car has got at either the flywheel or the wheels but I smile everytime I put my foot down, that's enough for me.
Nice post fella...you have done a cracking job to your motor.. :thumbs:
Noyjatat
Post by Noyjatat » Wed May 15, 2013 6:23 pm
Thanks buddy, looking forward to having it all done by August and then will be able to save some money again for something other than the car :D
Off for a detail next month too, looking forward to seeing how they get on and then as I said above off to MRC for the final piece to the puzzle.
Jamiestanton
Post by Jamiestanton » Wed May 15, 2013 8:14 pm
Here it is after the decoke I think its the map to do now
2006 black audi rs4 b7 mrc stage 2 stage 2 manifold de cats miltek coil overs light weight flywheel black optics 445bhp 470nm
ArthurPE
Post by ArthurPE » Wed May 15, 2013 8:33 pm
it made 370 first run, not 309?
it now makes more torque than stock with no other mods
332 vs 317
how is that possible since the displacement and compression ratio did not change?
50 HP gain at 7500
had to be a vaccum leak based on the droop after 5000 rpm
it now makes more than rated torque from 4500 to 6200
Jamiestanton
Post by Jamiestanton » Wed May 15, 2013 8:43 pm
That other one can not be my car look at date
Myn run 309 before carbon clean and vac leacking
ArthurPE
Post by ArthurPE » Wed May 15, 2013 8:46 pm
Jamiestanton wrote:That other one can not be my car look at date
good point
and the after is dated 4 days ago, not today
Jamiestanton
Post by Jamiestanton » Wed May 15, 2013 8:51 pm
It's not got to have stage 2 map so hopefully arround 440bhp what you think
Post by MikeFish » Wed May 15, 2013 9:03 pm
Jamiestanton wrote:It's not got to have stage 2 map so hopefully arround 440bhp what you think
I think they have given you someboy elses graph.
lengster1
Post by lengster1 » Wed May 15, 2013 9:16 pm
What mods has it got? You will need sports cats and cold air induction etc to get to 440 region.Full hog 460 requires no cats stage 2 manifold etc etc :biggrin3:
