1 st run on the dyno made 309 ps and 423nm has vac issues and in need of a decoke so when I get it back its should be a different car
Cock arse injectionwhat is cai
Hahahaha hahahahaSilas wrote:Cock arse injectionwhat is cai
Amar wrote:Flywheel, it's only you lot across the pond that do the 'at the wheels' rubbish.
actually converting to flywheel is 'rubbish'Amar wrote:Flywheel, it's only you lot across the pond that do the 'at the wheels' rubbish.
MaLicE wrote:Amar wrote:Flywheel, it's only you lot across the pond that do the 'at the wheels' rubbish.
technically its at the fly figures that are "rubbish" as you put it! when a car is put on a rolling road, the rollers which the wheels are driving is what gives the power figure, hence a AT THE WHEEL figure is acutally what power you are putting down on the road.
the AT THE FLY figure which everyone seems to get a boner about is a "guestimate" the rolling road operator has a "transmission loss" figure, that they input in to the computer to give a "at the fly" figure... the only way to get a true "at the fly" reading is to remove the engine and put it on an engine dyno where it will measure the power from the flywheel!
so if anything your comment is "rubbish".
Users browsing this forum: No registered users and 115 guests
