Cheers.
Kev.
Yep - just a little at the back but the front for sure - I want to match the front to the rear ride height without it being silly.otterolly wrote:looks spot on.....are you going lower on the v3's ?
Uhm -Big-blu wrote:Looks awesome!
Today I had to change my order from 10mm H&R spacers to 8mm because apparently they no longer make the 10mm with the 150mm hub diameter.
Your pictures definitely reassure me that 8mm and 275/30 v12 tires will look great.
I am amazed at how much 8mm a side can totally change the way the car looksjaysrs4 wrote:but those 8mm's are looking pretty good up rear
I think a lot of people run 275's as they offer a bit more rim protection plus they do look nice!jaysrs4 wrote:a lot of you like running pretty huge width tyres, 275's! That really surprises me.
I did my research and found that many guys run 275/30 pss with 10mm spacers all around with minimal rubbing under full load and hard cornering. I went with 8mm and 275 v12's (which are thinner than the pss) so should be good.sync24 wrote:Uhm -Big-blu wrote:Looks awesome!
Your pictures definitely reassure me that 8mm and 275/30 v12 tires will look great.I would double check your figures as 275x30 tyres are 20mm wider and with 8mm spacers you are likely to go beyond the wheel arch.
I originally wanted spacers with my 275's and Virdee [a spacer supplier/fountain of knowledge here] in as many words stopped short of not selling them to me.
I had a choice of 275's with no spacers or 255's with 8mm spacers to go with my setup especially as I am going to KWv3's
I would strongly advise you give him a call - I am sure he would not mind giving you the correct advice.
toyneg wrote:Looks great! How much does this cost out of interest?
I got 4 x 8mm H&R spacers,20 new longer bolts & 4 new longer locking wheel bolts for £215 from Virdee
Thanks! I've not had it done but the previous owner may have had some minor detailing last summer - I just keep it clean by hand washing weeklytoyneg wrote:that paint looks awesome, have you had the car detailed?
sync24 wrote:toyneg wrote:Looks great! How much does this cost out of interest?
I got 4 x 8mm H&R spacers,20 new longer bolts & 4 new longer locking wheel bolts for £215 from VirdeeThanks! I've not had it done but the previous owner may have had some minor detailing last summer - I just keep it clean by hand washing weeklytoyneg wrote:that paint looks awesome, have you had the car detailed?![]()
It's going in for a front and rear respray and a 5 day detail in June - I'll be well pleased if it looks anywhere near as nice as Sila's
This thread lists a handful of guys running 275/30 with 10mm.MikeFish wrote: 275 and 8mm spacers might be too much, 275 and 10mm is defo too much as I said in a post earlier today as the tyre is 20mm wide (10mm on inside and 10mm on the outside) added to a 10mm spacer is the equivalent of a 20mm spacer with the standard tyres and that is just too much with any weight in the back.
