Been have in a puff of smoke out the exhaust some one said may be valve stem seals told me to check plugs if see if any oil on them there all fine look perfect
I turn the car on let it run on stand still soon as oil temp gets to 86 to 90 get a puff of smoke then after about 10 sec it clears
Have no clue what this can be also good compression no probs there also no smoke when u floor it when u drive
Please help
I have brought a pcv valve and waiting to have this fitted
Also decoke was done 30k ago so is also booked in to have this done at mrc
I have also been filling oil to max on dip stick and everyone keeps telling me not to on these cars so oil is now just below max
Smoke rs4 b7 2006 any one had same issue
- Jamiestanton
2006 black audi rs4 b7 mrc stage 2 stage 2 manifold de cats miltek coil overs light weight flywheel black optics 445bhp 470nm
Re: Smoke rs4 b7 2006 any one had same issue
Haven't you asked this several times now?!
With the greatest of respect you're not going to get an answer on a forum Jamie. I've frequented car forums for nearly 9 years now and all you're going to get is hear say, gossip and ooooh's and errr's (no offence intended) - especially with a smoking engine!!
Although I'm new to RS246, I can see that there are lots of experienced owners here that are very knowledgable but all they can do is speculate over what could be something simple or something serious.
Your car is smoking and it could be countless causes. The only way to get it sorted is worked on by a specialist, no one here can realistically help or fix it for sure!
Hear, hear Jay!
- Silverfox42
I have had blue smoke on startup for the last 2.5 years, into Audi main dealers, replaced plugs, tried fuel cleaners etc etc, even had recent conversations with Audi technical.
Long and the short from all is that it is is an occasional trait of these cars and you live with it.
Check the oil level regularly, try to keep it close to minimum. Us VPower, not Tesco home brew and let the car warm up before opening the taps.
Current: 2017 S3 sportback
Previous:
Previous:
as long as oil consumption is not excessive and you don't have oil on the plugs or in the coolant, don't sweat it
since the engines are so high rev'ing tolerances are probably a bit loose until everything gets hot
mine does it, seems to be fuel more than oil
if I've been idling in traffic, first time I boot it I get a puff
If I don't drive mine and just pull it out the garage and back in again, the next time I start it, it smokes for a few seconds - All I keep thinking is all of that oil gathering in the galleys, oil ways and valves, so I usually take it for an unnecessary spin!
Jesus aren't they rich on choke too? It's almost neat fuel coming out the back of it until its warmed up.
OP - Just get it looked at, you could be screwing it more every time you drive it!!
Users browsing this forum: No registered users and 123 guests
