What is this?
Andyy
What is this?
Post by Andyy » Wed May 01, 2013 3:11 pm
Passenger side front caliper
Drivers side, with mystery part
I've had my brake warning light come on recently, oil level is fine.
What is it? Could this be the cause? Can i get the part alone or do i need a new caliper?
Batfinnk
Re: What is this?
Post by Batfinnk » Wed May 01, 2013 3:21 pm
Looks like the bleed nipple to me. The calipers are identical so the passenger on is probably on the bottom of the caliper. That is just a blanking plug as they are symmetrical.
Previous car: 2005 S4 B7.
Re: What is this?
Post by MikeFish » Wed May 01, 2013 3:26 pm
Yep, looks like a bleed nipple.
Batfinnk
Re: What is this?
Post by Batfinnk » Wed May 01, 2013 3:37 pm
Hahaha. He said nipple! Lol
Andyy
Re: What is this?
Post by Andyy » Wed May 01, 2013 3:45 pm
And could that be causing my warning lights? They're not perm, it seems to come on now and again (lets say 5-15 minute intervals) while driving and go between 5-60 seconds later.
Bat, checked the other side, it's at the top for both. At the bottom is some wire type thing (i must sound like such a dunce to any RS4 pro here)
Batfinnk
Re: What is this?
Post by Batfinnk » Wed May 01, 2013 3:47 pm
I think the most common thing to bring the wRning light on like that is normally a corroded or broken wire on the pad sensor.
Andyy
Re: What is this?
Post by Andyy » Wed May 01, 2013 3:50 pm
Just had new disks and pads fitted all round in jan by MRC, Is the pad sensor not a part of the pads ( i remember them having cables)
Batfinnk
Re: What is this?
Post by Batfinnk » Wed May 01, 2013 3:54 pm
Yes it is. More likely to be where it connects to the car side of the loom. It is a little connector attached to the hub assembly. Could be moisture in there. Worth popping off and squirting with some wd40 or something along those lines.
Andyy
Re: What is this?
Post by Andyy » Wed May 01, 2013 3:58 pm
Ahh ok, well i think i'm going to take it a specialist just as i'm not comfortable messing with it since it's a company car lol but at least i can try cut down the cost of diagnosis if i can give him a few places to look first
Youngben
Re: What is this?
Post by Youngben » Wed May 01, 2013 6:13 pm
that there is a bodge for 1! they have replaced the bleed nipple for a grub screw by the looks of it! both calipers should have 2 bleed nipples (one either side of the caliper) at the top! looks like that one may of got damaged or broken off and they have replaced it with a grub screw rather than get a new nipple or replace the caliper if they have had to re drill and tap the hole after the damage! as you say at the bottom of both calipers in the same place will be a pipe connecting both chambers/sides of the caliper for the fluid to travel across the caliper!
In regards to your question on brake lights on i would check your sensors! this can be done with a simple multi meter by disconnecting the plug and checking there is still a join all the way through the circuit!
sonny
Re: What is this?
Post by sonny » Wed May 01, 2013 6:37 pm
Yep your missing a bleed nipple!
Some callipers have bleed nipples at the bottom, this is so that they can be used on both sides of the car. You cant bleed a car using the bottom bleed nipples as air will rise in the calliper resulting in the top pistons not being able to be forced out.
Not sure how you will be able to repair that.
sonny
Re: What is this?
Post by sonny » Wed May 01, 2013 6:39 pm
The wires entering the pad wear sensor connection blocks can tend to brake loose causing a closes circuit. You should be able to see clearly
joesnow
Re: What is this?
Post by joesnow » Wed May 01, 2013 7:10 pm
Company car?? Got any jobs going??
Current: 2010 A6 2.0 TDi
Gone: 2006 B7 RS4 Avant
Andyy
Re: What is this?
Post by Andyy » Wed May 01, 2013 7:44 pm
Cheers for the replies guys, all helpful stuff.
Yeah, company car :) get's better :P I'm 22 I have a cool boss :P
Ahh, hadn't noticed it was plugged with something else.
also it's not the brake pad warning light. It's the red warning light that's to say you have a fault in your braking system. Just encase anyone wasn't certain what i meant
brn7y
Re: What is this?
Post by brn7y » Wed May 01, 2013 8:24 pm
Don't fancy your company car tax bill!
Users browsing this forum: Google Adsense [Bot] and 136 guests
