Secondary air pump
Secondary air pump
Hi all, need some help. After changing the Secondary air pump, does the car need to be reset with Vagcom to take of engine management light.
Re: Secondary air pump
If you've fixed the problem, it'll eventually go off. Eventually.
It's only FIVE POUNDS for an ebay special blue KKL cable and VCDS Lite is the mighty sum of ZERO POUNDS!
Go on... Splash out a little
Recycling dinosaurs for fun
Could you pls give me the link to one that works. As the last lead, I bought didnt work. Would be much appreciated.
Sure, no probs. I use something very similar to this with much success:
KKL Cable Link
Ignore any driver CD you get with it and use these drivers direct from FTDI:
Drivers Link
I have a pretty comprehensive array of diagnostic tools & my trusty cheap blue kkl cable is the one i turn to most.
KKL Cable Link
Drivers Link
Thanks Sweegie for the link.
The engine management light has gone now. Phew.
Users browsing this forum: srichards and 97 guests
