Best of luck that they don't find anymore dramas...
I had a look at mine last week as best as I could on the ramps with the undertray off and it was ok, no leaks.RS6chris! wrote:The engine on these knocks out some serious heat...don't know if that would cause gasket failure?
As I've said already my leaks can't be seen from under the bonnet?...just hope everyone else's cars aren't slowly suffering the same fate as mine?
The only leak that Audi found initially was the oil pump?..because they removed the plastic under-tray to change oil this seeing the leaked oil on it.
The three today have only been found because engine is out?
At least when sorted I've piece of mind for a few years??....if I decide to keep it!!!!!!
