EPC light on again, no wait it's off again.......
TonyRockyHorror
Post by TonyRockyHorror » Wed Apr 17, 2013 3:33 pm
Groan
Wife has the car today - she calls me to say the EPC light is on.
I call Audi Assist and they're sending someone tonight to check it out. Now she calls and the light's off.
I wish it'd make its mind up!
:audibash:
What can cause the EPC light to come on and then go off of its own accord? I'd have thought that if the ECU logs and "event" then it would stay on until the fault codes are cleared??
Help!
:kissmyrings: :mrgreen:
Spaceman_RS4
Re: EPC light on again, no wait it's off again.......
Post by Spaceman_RS4 » Wed Apr 17, 2013 7:09 pm
Engine mount
Ordered b9 S4 Avant ibis white
Panther black 8V RS3
Misano Red B7 RS4 Saloon
yorkie
Post by yorkie » Wed Apr 17, 2013 9:25 pm
Will be the manifold flaps sticking. VCDS will confirm but that is the usual symptom.
adsgreen
Post by adsgreen » Thu Apr 18, 2013 12:27 pm
yorkie wrote:Will be the manifold flaps sticking. VCDS will confirm but that is the usual symptom.
+1
Could be any number of things but this is likely.
I wouldn't call audi assist based on the EPS light alone.
That simply is audi's own diagnostic saying 'something isn't quite what it should be'.
If the problem is bad enough the car will trip the generic mil light. This means problem should be looked at, possibly in limp home mode but again drive able.
Any serious problem would trip the flashing mil light (and most likely multiple misfires).
This is 'stop as soon as safe to do so'
RS4RAA
Post by RS4RAA » Thu Apr 18, 2013 1:42 pm
Ist of all hello, I've been on here a while and not said Hello.
I've had this problem on mine. When the light was on it wouldnt rev beyond about 6750. Took it to Teesside Audi for this and other things and they ordered a Solenoid Valve V037 906 283 C @ £54.09 plus fitting @ £80.50 and it cured it.
Hope this helps.
Richard.
adsgreen
Post by adsgreen » Thu Apr 18, 2013 4:55 pm
without plugging in the diagnostics you can't tell what it is... hundreds of things can trip the EPS light.
TonyRockyHorror
Post by TonyRockyHorror » Fri Apr 19, 2013 11:59 am
:thumbs:
Thanks all.
It's stayed off. It's had the manifold flaps done a couple of weeks back under warranty when it came on before.
Italian tune up this weekend, I think :-D
adsgreen
Post by adsgreen » Fri Apr 19, 2013 12:50 pm
If it comes back and you can't beg/borrow/steal a Vag Com unit then worth spending 20 quid in Halfords to get a generic odb2 reader. Whilst not as detailed it will at least give you the code which would help point the finger at the underlying fault.
Worth checking that the flaps are operating by revving the car up over 4k if you haven't already.
TonyRockyHorror
Post by TonyRockyHorror » Fri Apr 19, 2013 2:36 pm
Cheers bud.
Yeah I'll organise a fault code reader this weekend.
Missus has been tootling round in it for a few days. I reckon it just needs a good italian tune up.
:greyrs4:
Users browsing this forum: Burty, Majestic-12 [Bot] and 107 guests
