DIY, Front brake pads and disc replacement
Re: DIY, Front brake pads and disc replacement
Ahh yes they can be a nightmare to get out. Hope you get it sorted.
- Tile Diver
Man, I also took on the job of changing front discs and pads, and like yours the pad retaining pins were a nightmare, I had 3 that just wouldn't budge!!!esp_mm-270 wrote:Well, had a go friday and its booked in for weds. Failed at the first hurdle, n/s/f upper pad pin was friction welded or jammed in. Looks like it was a problem last time the pads were done as the point of the pin was flattened (no copper slip in there either)Spose I could've purchased a dremel and cut it out but I had gotten the hump by then
Oh well, will be done soon and she'll be back in business(Meaning love my Audi)
M
I ended up nipping the brake hoses, removing the calipers on both sides, taking them down to the local garage where they had to apply some heat and a lot of hammering, finally they came out!!
So back up to the house it was, bang the calipers back on the car, bleed the brakes and Hey Presto all sorted!!!!
I'll do anything not to give the stealers money, and I made sure all the pins were well copper slipped. I'm actually that paranoid about having the pins seizing again I actually remove the pins now and then and copper slip them again!!!
Black Optics / Ti Pack
SS Suspension +
Sunroof
H&R Hubcentric Spacers
Milltek Res / Valved Cat Back
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
If in doubt.. Power out!!
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
- esp_mm-270
- Tile Diver
esp_mm-270 wrote:^^^^^^^ Thats not a bad idea
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
I had a couple stuck pins when I done mine. What I did was leave them as they were and simply remove the pads from the inside. Save buggering a about and damaging anything.
Ordered b9 S4 Avant ibis white
Panther black 8V RS3
Misano Red B7 RS4 Saloon
Thanks for posting this Sonny, I am going to take this on soon and this is a great help!
RS4 B7 Misano Red Saloon / Black Optics / Revolution - Pipercross Carbon air intake / Carbon Clean / Black Rings / Lepsons Black Chrome Alloys
Sonny's good too he did mine for me.
Hi There,
Just a little tip I have used over the years when changing brake pads,
When the brake fluid level rises as you open the calliper pots I use a small ( empty )plastic bottle say around 250ml with nozzle and what you do is squeeze all of the air from the bottle stick the nozzle into the brake fluid keeping the nozzle submerged and let the bottle suck out the excess! wham no mess, then providing the bottle is (very clean) you can re - use the fluid if needed...when the level settles
Richard
Richard
RS4 B7 Avant,2007
Metallic black, Black optics pack, Black gloss Wheels, Milltek black tipped -valved, MRC Installed TTS Supercharger 610ps/626nm, MRC stage 3 remap, CAF, DRC/SS+ with H&R spacers, carbon race splitter, carbon trim
Users browsing this forum: Google [Bot] and 120 guests
