DIY, Front brake pads and disc replacement
PhilT
RS246.com
Re: DIY, Front brake pads and disc replacement
Post by PhilT » Mon Apr 23, 2012 12:59 pm
GLOL
Post by GLOL » Sat Nov 17, 2012 8:09 pm
Replaced both front discs and pads with OEM yesterday, but now the brake warning symbol keeps coming on in the dash. This happened after changing the first side. I've taken the wheel back off today and re-seated the sensor but it still comes on. Sometimes not, but then will after a short drive.
Any ideas?
Post by Shoppinit » Sat Nov 17, 2012 8:11 pm
Have you checked your brake fluid?
GLOL
Post by GLOL » Sat Nov 17, 2012 8:18 pm
Yep, in fact that overflowed, had to soak some out. Could it be too full?
Post by Shoppinit » Sat Nov 17, 2012 8:21 pm
No, but have you checked it since? Might have gone down.
What is the exact symbol you are getting?
sonny
Post by sonny » Sun Nov 18, 2012 2:30 am
Make sure the new pads wear sensors are fitted correctly ( push in connectors) or that one of the wires has not split/snapped at the calliper connections.
GLOL
Post by GLOL » Sun Nov 18, 2012 2:34 am
Symbol is the yellow circle with pads each side.
After we changed the first side, I turned the car around for better access and noticed the symbol. I've checked that side and the sensor seems OK. Sometimes the car will start without the sensor indicating, but come on after driving. MTS be earthing somewhere...
Terry1948
Post by Terry1948 » Sun Nov 18, 2012 11:05 am
Mine does that sometimes I think the connector is slightly corroded. It will correct it self for a while and then come back on for no apparent reason. I just put up with it. when the weather gets warmer and I have some spare time I will clean the connectors.
sonny
Post by sonny » Sun Nov 18, 2012 11:52 pm
I had this also when I fitted my race pads. The wires I had used to bridge the connections had corroded at the base of the plastic connector. You would never have noticed it unless you got up close.
Worn pads sometimes bridge the connection on the wear sensors tripping the wear sensor, but then it may open the connection due to pad dust/debris moving about.
GLOL
Post by GLOL » Wed Nov 28, 2012 3:42 pm
Turned out to be the connection - pulled it apart and 'cleaned' it with a jewellers screwdriver just by poking around to clear corrosion dust. Put back together, 300 miles yesterday, now issues :-)
esp_mm-270
Post by esp_mm-270 » Wed Apr 10, 2013 6:21 pm
Does anyone know the size of the hex bolt that hold the disks in place? Its the tool in this job I don't have and doing them over the next few days.
Thanks in advance, Mark.
Surrey Sam
Post by Surrey Sam » Wed Apr 10, 2013 6:47 pm
It would a Torx head socket required, looking at the thread I've linked to below they say on there that the size is a T30:
http://www.euroaddiction.net/forum/b7-r ... w-diy.html
I haven't had my wheels off yet to inspect, so can't confirm for sure.
Ranger Rico
Post by Ranger Rico » Wed Apr 10, 2013 6:48 pm
It's a T30 torx, at least it is on the rear, I'm sure it will be the same on the front
esp_mm-270
Post by esp_mm-270 » Thu Apr 11, 2013 3:52 pm
That's great, thanks very much :)
esp_mm-270
Post by esp_mm-270 » Mon Apr 15, 2013 5:30 pm
Well, had a go friday and its booked in for weds. Failed at the first hurdle, n/s/f upper pad pin was friction welded or jammed in. Looks like it was a problem last time the pads were done as the point of the pin was flattened (no copper slip in there either) :( Spose I could've purchased a dremel and cut it out but I had gotten the hump by then :FIREdevil:
Oh well, will be done soon and she'll be back in business :kissmyrings: (Meaning love my Audi)
M
Users browsing this forum: Google [Bot], rook13pdx and 129 guests
