Anyone have there decoke pre+post results?
sar
Re: Anyone have there decoke pre+post results?
Post by sar » Tue Mar 05, 2013 12:53 am
Silas wrote:Good to hear your pleased with the results, however I do think AMD big the gains up, compared to rolling road at MRC,anybody else see this??
:nodder:... normally to get 450 bhp out of an rs4 it needs everything but the kitchen sink throwing at it.
RSKiwi
Post by RSKiwi » Tue Mar 05, 2013 1:43 am
I have 450 and it took all of my sig to get there at MRC. Always been a bit sceptical of AMD's claims although judging by what Okis car already has on it a decoke and AMD map could get there, especially if the manifold has been done and you dont know.
____________________
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Pug 405 NZ Touring Car
Toyota Landcruiser
sakimano
Post by sakimano » Tue Mar 05, 2013 5:21 am
That's why the dyno is not very useful. It may help tuners dialing in a nice curve but for the end user do you care what a piece of paper tells you your car is capable of, or do you care of what your car actually does?
That's why I have never and will never dyno my cars. I just don't see the point other than to say to someone at a party 'you know with my remap and exhaust I'm making 440 hp'
I would much rather know what my car is capable of in certain acceleration tests...and of course I would rather just drive my car.
RIV
Post by RIV » Tue Mar 05, 2013 10:07 am
Saki the reason why you don't dyno is because your car is probably running 360, ignorance is bliss
klauster
Post by klauster » Tue Mar 05, 2013 10:40 am
Here is a link to mine when it was done last year:
http://forum.rs246.com/viewtopic.php?f= ... 5&start=15
klauster
Post by klauster » Tue Mar 05, 2013 10:43 am
IMHO Amd Rollers are a bit on the high side, the performance gain is still relative, as before and after are on the same rollers... more likely the numbers should be 20 down....
murph7355
Post by murph7355 » Tue Mar 05, 2013 11:29 am
sakimano wrote: I would much rather know what my car is capable of in certain acceleration tests...and of course I would rather just drive my car.
Indeed.
A rolling road is useful for before and after comparisons, but only if operated independently.
Figures from a rolling road can, and are, tweaked by operators. Often out of necessity. So unless you can 100% guarantee exactly the same allowances were made on both runs, (which is very hard to do), the outright figures should be used as a ball park only.
And at the end of the day, if a "390" car can out pace a "430" car over a quarter mile or in third between 3k and 8k, one or both figures are not right :)
Seeing a nice big number doesn't half do a lot to ease the wallet pain though :grin:
spikeyboy101
Post by spikeyboy101 » Tue Mar 05, 2013 2:47 pm
Would agree that AMD figs do seem to come out a bit high - having said that they do a before and after run so you can see the "over all" change.
murph7355
Post by murph7355 » Tue Mar 05, 2013 5:32 pm
spikeyboy101 wrote:Would agree that AMD figs do seem to come out a bit high - having said that they do a before and after run so you can see the "over all" change.
Depends how cynical you are :)
sakimano
Post by sakimano » Fri Mar 08, 2013 6:02 am
Silas wrote:Saki the reason why you don't dyno is because your car is probably running 360, ignorance is bliss
I guess that's possible. However my car, bone stock, ran the quarter mile at a certified dragstrip in 12.75 @ 108 (in other words faster than any magazine to ever test a stock rs4), so ignorance if that's what you call it is fine by me.
Ever do any actual acceleration testing of your performance car? I mean who cares about printouts from a computer...really.
mark758
Post by mark758 » Thu Mar 14, 2013 12:27 am
MikeFish wrote:
OskiRs4 wrote:
mark758 wrote:My pre / post figures on an MRC de-coke were 370/430 - both results taken on the Banbury RR.
Definitely feel 60bhp :-) Improvements to my engine airflow were outstanding.
Hi mate was that just a carbon clean? No other work?
His signature says MRC stage 2 430bhp so it sounds like he has had other work done, be it before or after the decoke I don't know. One things for sure, you wont be getting 430bhp out of a 6 year old RS4 with a standard engine, decoke or not. I suspect if he went from 370 to 430 he had decoke and stage 2 at the same time.
I had a stage 2 map already, albeit from another supplier improving top end, but I didnt like the throttle response it gave. Not entirely sure how the age of the vehicle is relevant. I see some fantastically disfunctional engines not a year old :-)
No other work done. I was keen the before and after difference was recorded on the same rollers. I had another run done on a different set of rollers known to me afterwards to ratify...as much as you can with RRs...
Certainly the improvements I value can be seen on the timings on the RaceLogic....much better than factory for sure ;-)
2013 Ibis White RS7¬
¦ParkingPackPlus¦Sunroof¦HUD¦AudiConnect¦HeatedRearSeats¦RearSideAirbags¦RedBrakeCalipers¦QuattroPuddelights¦SoftCloseDoors¦NightVision¦Dynamic Package¦CarbonPackage¦CarbonMirrors¦21" GlossBlack¦ACC¦Stop&Go¦PreSensePlus¦SideAssist¦LaneAssist¦B&O¦BlackOptics¦OEMBlackBadging¦Gyeon Q2 Duraflex¦
ArthurPE
Post by ArthurPE » Thu Mar 14, 2013 1:20 am
his car ran one of the fastest times I've ever seen for a stock or modded NA RS4
high mileage, never cleaned
think about it
Covkiller
Post by Covkiller » Tue Apr 09, 2013 11:13 am
My RS4 has a Revo map
MRC Dyno’d on Monday @ 399.4PS
Doug mentioned it could do with a carbon clean. So it’s booked in this Thursday for a full clean, valves, stems, inlet manifold etc. The car will be put back to standard with no mods to the inlet manifold other than porting and polishing.
Revo said they’ll remap my car free of charge once done and MRC says they’ll re-dyno it afterwards.
This should prove interesting and lay to rest all of the questions asked in forums as to the benefits of an RS4 B7 Carbon Clean.
S4Player
Post by S4Player » Tue Apr 09, 2013 3:10 pm
Covkiller wrote:My RS4 has a Revo map
I think the Arthur test is the best way to test the benefits of a carbon clean, not a dyno
Noyjatat
Post by Noyjatat » Tue Apr 09, 2013 3:59 pm
I am planning to have the MRC one this summer, along with a stage one remap.
I am not sure if the car has ever had it done so will be interested to see how things go but regarding peoples opinions which seem varied I am not doing it for power gains as much as giving the engine a good clear out and making sure the set up is as it should be.
I will post before and afters here regardless for others to discuss as they wish. To be honest I am more about enhancing the cars looks than giving it more grunt and am probably one of the few that prefers to have the standard exhaust noise :)
Users browsing this forum: No registered users and 96 guests
