Bonnet Venting
Re: Bonnet Venting
Wonder if its worth removing the rear under bonnet rubber weatherstrip so heat gets drawn out and over the windscreen.
Re: Bonnet Venting
Not a bad idea that.
Re: Bonnet Venting
...prob all under bonnet weatherstrips...adsgreen wrote:Wonder if its worth removing the rear under bonnet rubber weatherstrip so heat gets drawn out and over the windscreen.
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
Re: Bonnet Venting
I guess the V8 was deliberate? 8 slots below the V.R8GXR wrote:Well heres mine, all nicely stamped out, just needs sanding and paint.
Re: Bonnet Venting
Actually no...... But well spotted. For everyone else, yes I had the V and 8 slots to replicat V8.chunky79 wrote:I guess the V8 was deliberate? 8 slots below the V.R8GXR wrote:Well heres mine, all nicely stamped out, just needs sanding and paint.
Re: Bonnet Venting
For the ones interested...
- Attachments
- RS6 Hood Vent Templetes.pdf
- (1.17 MiB) Downloaded 94 times
Yellow Koni's
Yellow Koni's
Re: Bonnet Venting
It's a common misconception that air flows OUT at the back of a bonnet. Hence why you don't see race cars with the back end lifted up essex style.adsgreen wrote:Wonder if its worth removing the rear under bonnet rubber weatherstrip so heat gets drawn out and over the windscreen.
There is normally a HIGH PRESSURE area at the bottom of the windscreen causing air to flow INTO the bay which is why the cabin air intake is always there.
Blue is low pressure red is hIgh pressure. The pic is not RS6 specific but generaly speaking vents in the center of the bonnet work better than vents at the rear of it.
C5 S6 4.2ltr V8, black, muffler-ectomy, RNS-E + bluetooth, 20" B7 rs4 style alloys, more to come.........
Re: Bonnet Venting
all in all, the Sportec vent mod is by far the most easy/cheap mod you can do really, the amount of heat going through it is huge (heard of one wanting to know if it really works: he couldnt hold his hand more then 30 seconds cos of the air coming out, and thats while at a standstill, let alone while driving and more air gets drawn out of the engine bay.
What keeps me from doing it is the risk of dirt/animals going in...
Yellow Koni's
Yellow Koni's
Re: Bonnet Venting
You mean like a bear or whale mav?
Re: Bonnet Venting
Yellow Koni's
Yellow Koni's
Re: Bonnet Venting
That there would have my size 11, fecking hate cats!
Re: Bonnet Venting
I'd nevered considered that.jordan wrote:It's a common misconception that air flows OUT at the back of a bonnet. Hence why you don't see race cars with the back end lifted up essex style.adsgreen wrote:Wonder if its worth removing the rear under bonnet rubber weatherstrip so heat gets drawn out and over the windscreen.
I guess I always thought the airflow over the windscreen would be less compressed but those pics say otherwise.
So the air is hitting the windscreen and instead of immediately flowing over is just sitting there getting higher pressure before it goes...
Re: Bonnet Venting
Yellow Koni's
Yellow Koni's
Users browsing this forum: JensonIsGinger and 72 guests
