B8 RS4 and engine carbon issues
Re: B8 RS4 and engine carbon issues
here a prime example http://forum.rs246.com/viewtopic.php?f= ... hilit=fail in the end they admitted they could not do the B7 RS4 so yes big clames and no picture to back it up
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Re barryrs comment
Yes that looks like it. I'll be in contact with terraclean to see when it will be in the uk.
But the post does state they can not do the B7 RS4
Sent an email to Terraclean stating I have a B7 RS4 and was interested in having this new service and got this reply:
Hello Mark
We do not have the item in stock but i have asked some questions of our
Canadian partners.
Regards
Martin C Dowd
Managing Director
I'll send an update if I get a further reply
Hello Mark
Canadian partners.
Regards
Martin C Dowd
Managing Director
My b8 RS 5 pulled 432PS on MRC dyno
- Revolution
- Trader (Expired)
supercharge it...!
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
can the s-tronic take it?Revolution wrote:supercharge it...!
Sure can ads there's a few kits about to be released shortly. Pes whipple and apr tvs1720 kit but to name two
Maybe I missed something but I don't see how Super Charging will fix the carbon issue?
Read the comments above and you'll see why supercharging was mentioned. When mines was supercharged after 20k miles it was removed to fit another kit and Doug commented i how much cleaner it was when compared to an NA car. So maybe it helps
The carbon problem does seem to be generally self limiting - probably due to a combination of factors but I would expect temperature and air charge speed to play a role. Under full throttle the supercharger will be flowing considerably more air so you'd hope it'd loosen things a bit more.
VW acknowledge that high engine temps help remove things and again more power results in more heat.
Finally iirc the vacuum system on the rs4 uses a Venturi effect so faster airflow may make the oil separator work better
Audi doesn't think so (no dsg on RS6/7 or S8).adsgreen wrote:can the s-tronic take it?Revolution wrote:supercharge it...!
PS. The term S-tronic can now refer to the dsg or tiptronic auto transmissions. The rs6 has s-tronic for example, even though is the 8 speed tip.
dsg/tiptronic/s-tronic are all different,sakimano wrote:Audi doesn't think so (no dsg on RS6/7 or S8).adsgreen wrote:can the s-tronic take it?Revolution wrote:supercharge it...!
s-tronic is the only one with dual cluch, faster shifting (0.2s) and rev-matching on down shifts,
the s-tronic RS7 TT V8 got about 700Nm of torque so clearly the gearbox can cope with that, supped V8 RS4/RS5/R8 will have no more then 600Nm, so wouldn't worry
RS6/7 is 'S-Tronic' but as above it's a slosh box, not the same as in RS4/5. S6/S7 have dual clutch but that level of tune has lower torque output.
I would have agreed on the comments about the slush box...
But after driving a new 8 speed ZF and a 135m one I think they will take over.
You can not tell the difference between them in practise and make for much smoothe driving when not on it.
Seriously fast shifts and proper blips on down change.
I'm not a fan of any auto tech (just personal preference) however I was mighty impressed with the new slush boxes.
I would wager that they are slighter and less complex than the dsg's so could see a trend towards them.
Users browsing this forum: Google Adsense [Bot] and 44 guests
