AP Racing Front Discs
Re: AP Racing Front Discs
edited my post, standard are 365mm but jhm do a 380mm disk
I would jump in a buy a pair of front Disc for My RS as well see if we can get a deal if we were to buy X amount.
- MartayMcFly
- 5th Gear
I need to replace front and rear discs... if its more or less the same price as OEM then I'm in, if its going to be £600+ for each pair then maybe not.
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2015 8V RS3 Stage 3 - sold
2017 Alfa Giulia Quadrifoglio
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
I couldn't get hold of the guy today, so will be trying again tomorrow.
I will ask about group discount and see what we can get.
T'
T'
B7 RS4 Cabriolet....... All round nice bloke......
Got B7 setup on my B5 and going to need new front and rear discs soon so interested to see what you come back with!
I noticed there is a different part number for the left and right disc, so is it safe to assume that they are correctly drilled (unlike OEM discs)?
They appear to weigh slightly more than OEM (12.3kg vs 12.06kg) whereas the Lobas are just 8.7kg - but this is contradicted by the download page which gives Assembly Mass as 9.45kg. Is it's as simple as one weight with the bells and one without, and if so, which measure should be used to compare with OEM?
I also see that minimum thickness is 32.5mm compared to 32mm OEM - again, not sure if this is relevant...
2007 Daytona RS4 Avant
I contacted AP about a set + bells and they put me in touch with a supplier in Ireland.
The cost came in at €800/£682 collected and the lead time was quite long due to the Xmas period.
I ended up going with drilled Tarox ( and Yellow stuff pads) from Revolution cuase of there price with the group by, smashing service too from Glen and the boys!
Rule #1edge wrote:I contacted AP about a set + bells and they put me in touch with a supplier in Ireland.
- MartayMcFly
- 5th Gear
I'm thinking I should have done the same... but December was a pretty tight month cash-wise. I got the pads though.edge wrote:I contacted AP about a set + bells and they put me in touch with a supplier in Ireland.
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
I will sort out thoes pics!MikeFish wrote: Rule #1
Yeah, it wasnt fun, but couldnt pass it up!MartayMcFly wrote:I'm thinking I should have done the same... but December was a pretty tight month cash-wise. I got the pads though.
Hi all,
Phoned again today but the guy I need to talk to is at Donnington Park for a press day for next months BTTC. Was told he will be in tomorrow, so will call him then.
T
T
All,
Spoke to Tim Phillips at Circuit Supplies regarding the AP front disks.
The cost of these are: £312.66 + vat each side, This INCLUDES the AP mounting bells.
Total cost per front end £650.40 inc vat. He has offered 10% off as standard if we say we are on the this forum, bringing it down to £675.34 per pair. After 1st purchace, you only need to buy the rotors which list at £233.58 + vat - discount, so in future £504.53 a pair.......
He also said that if we got together and did a group buy, he would give more off.
He also said that the Ferrodo DS2500 blue pads are really good, they are for fast road/track days, work really well from cold and are very kind to discs. Im not up on this stuff so has anyone got any knowledge of these pads? They retail for £267 + vat (£320.40 inc) and he was willing to "knock some off that"
Finally, they would be more than willing to make rear discs, but would need a specimen. Does anyone have an old one knocking about that we could get to him. Circuit supplies ar in Leighton Buzzard.
Hope this helps.
Terry
Hope this helps.
Terry
Sorry,
Should be £750.40 before discount.
Homer Moment....
Homer Moment....
From memory the only down side to the DS2500 pads is that they don't have wear sensors. I could be muddled up though.
