Part Number Guide
- TonyHayers
- 5th Gear
Part Number Guide
I've been maintaining a list of part numbers for a while now and realised that it might be useful to have a sticky page with some common part numbers on it. So here's what I've got so far. Pls add a comment with any additions/corrections (or if something isn't that useful I can remove it:) I'll then edit this original post to reflect the corrections and hopefully it will be useful for those of us who don't have access to EKTA (or those who do and get their minds blown by it's complexity!).
Common Servicing Items
Oil filter: 079 198 405 E
Oil sump plug: N01 602 76
Oil sump plug washer: N01 381 57
Air filter: 079 133 843 A
Cabin filter (active carbon): 4B0 819 439 C
Windscreen wiper blades: 4B2 955 425 C
Spark plugs: 101 905 621 C
Fuel filter: 4F0 201 511 E
Headlamps (Non-adaptive)
Pre-facelift (orange indicator caps)
Left: 8E0 941 003 AN
Right: 8E0 941 004 AN
Post-facelift (clear indicators)
Left: 8E0 941 029 BN
Right: 8E0 941 030 BN
Xenon ballast
8E0 907 391 B
Headlamps (Adaptive/AFS)
Left: [TBC]
Right: [TBC]
Left: 8E0 941 029 BQ
Right: 8E0 941 030 BQ
Xenon ballast:
8P0 907 391 (supercedes 8E0 941 329 A)
Suspension
Shock absorbers
Front left: 8E0 412 019 B
Front right: 8E0 412 020 B
Rear left: 8E0 512 019 E
Rear right: 8E0 512 020 E
DRC Accumulator valve:
8E0 616 887
DRC hydraulic oil:
G 052 731 A2 [Qty TBC]
Springs (standard)
Front: [TBC]
Rear: [TBC]
Springs (SS+)
Front: [TBC]
Rear: [TBC]
Braking
Handbrake
Handbrake lever: 8E0 711 305 P
Handbrake cable: 8E0 609 721 BB
Front brakes - Standard
Disks (pair): 8E0 615 301 AB
Pads (set): 8E0 698 151 Q
Rear brakes - Standard
Disks (pair): 8E0615601AB & 8E0615602D (rear disks are directional)
Pads (set): 8E0 698 451 P
Front brakes - Ceramic
Disks (pair): [TBC]
Pads (set): [TBC]
Rear brakes - Ceramic
Disks (pair): [TBC]
Pads (set): [TBC]
Clutch
Clutch plate: 079 141 031 A
Pressure plate: 079 141 11DX
Clutch release bearing: [TBC]
Dual mass flywheel: 079 105 266 F
Master cylinder: 8E1 721 401 AJ
Slave cylinder: [TBC]
Clutch pedal switch: 7H0 927 189 (supercedes 8E0 927 189 B)
Air Intake System
Airbox snorkel: 8E0 129 617 D
Airbox housing (incorporates MAF mount): [TBC]
Air intake hose (airbox to throttle body): 8E0 129 627 M
Dashboard
RNS-E DVD Sat Nav Unit: 8E0 035 * (multiple)
RNS-E to CD Changer Cable: 8E0 051 592 B
Climate control head unit: 8E0 820 040 BM
Black Optics
Parts for Black Optics retrofit (Saloon).
Grille: 8E0 853 651 AF VMZ
Roof moulding (left): 8E5 853 703 M 1P9
Roof moulding (right): 8E5 853 704 M 1P9
"window aperture seal" (left outer): 8E0 837 477 C
"window aperture seal" (right outer): 8E0 837 478 C
"window aperture seal" (left outer): 8E0 839 477 C
"window aperture seal" (right outer): 8E0 839 478 C
Side window: 8E5 845 299 T NVB
Side window: 8E5 845 300 T NVB
Bumper strip: 8E5 807 443 G GRY
Interior
Armrest with Phone Prep: 8E0 864 207 G6 PS
Armrest cover to fit above: 4B0 864 245 AP 47U
Screw required for retrofitting armrest: N 964 862 04
iPhone 4/4S cradle for armrest with phone prep: 8T0 051 435 F
Gear knob & leather gaiter: 8E0 863 278 DR TAV
Exterior
Lower left front door moulding/blade: 8E0 853 959 7DL
Lower right front door moulding/blade: 8E0 853 960 7DL
Misc
Ignition coil: 07K 905 715 F
Aircon drier unit: 8E0 820 193 J
Windscreen (for rain sensor option): 8E0 845 099 AG NVB
Gas struts for boot (Saloon): 8E5 827 552 K
Xenon ballast
8E0 907 391 B
Left: [TBC]
Right: [TBC]
Xenon ballast:
Suspension
Shock absorbers
8E0 616 887
DRC hydraulic oil:
Springs (standard)
Front: [TBC]
Rear: [TBC]
Springs (SS+)
Front: [TBC]
Rear: [TBC]
Braking
Handbrake
Disks (pair): [TBC]
Pads (set): [TBC]
Disks (pair): [TBC]
Pads (set): [TBC]
Clutch
Air Intake System
Dashboard
Black Optics
Interior
Exterior
Misc
06 Phantom Black Saloon:
^ GONE
^ GONE
- PetrolDave
Re: Part Number Guide
There are many versions of the RNS-E that might have been fitted over the production run of the RS4, see http://audiforum.us/threads/audi-a4-s4- ... bers.6851/ for a more complete list.
Pretty good idea and good start of a useful list. Just one suggestion would it be worth putting prices with each one. May not be 100% correct at all times but useful as a rough guide.
Previous car: 2005 S4 B7.
Really useful addition to the thread and well worth a sticky...
- TonyHayers
- 5th Gear
Thanks Dave, updated with link to that listing.PetrolDave wrote:There are many versions of the RNS-E that might have been fitted over the production run of the RS4, see http://audiforum.us/threads/audi-a4-s4- ... bers.6851/ for a more complete list.
^ GONE
^ GONE
- TonyHayers
- 5th Gear
Yeah, I did think about that and agree it might be useful - but with prices fluctuating quite a lot it might be an effort to maintainBatfinnk wrote:Pretty good idea and good start of a useful list. Just one suggestion would it be worth putting prices with each one. May not be 100% correct at all times but useful as a rough guide.
^ GONE
^ GONE
I don't think anyone would expevt the prices to be continously updated but would be useful as ballpark figures.
Audi RS4 B7 Saloon (and I assume Avant?) Windscreen with Autolights / Wipers Option 8E0 845 099 AG NVB
Armrest with Phone Prep Black, Saloon (possibly avant too) 8E0 864 207 G6 PS
Armrest cover to fit the above armrest with black leather cover 4B0 864 245 AP 47U
Lower left front door moulding / blade 8E0 853 959 7DL
Lower right front door moulding / blade 8E0 853 960 7DL
- TonyHayers
- 5th Gear
Thanks Will. Added.WillRS wrote:Audi RS4 B7 Saloon (and I assume Avant?) Windscreen with Autolights / Wipers Option 8E0 845 099 AG NVB
^ GONE
^ GONE
no probs - although the door blades aren't interior bits really as are the lower bit of the door so an exterior part. maybe a bodywork / exterior trim parts section is needed ? not meaning to sound pedantic !
oh also could add
8T0051435F - iPhone 4 / 4S cradle - fits in armrest with phone prep..
oh also could add
- TonyHayers
- 5th Gear
Ah yeah, cheers. done.WillRS wrote:no probs - although the door blades aren't interior bits really as are the lower bit of the door so an exterior part. maybe a bodywork / exterior trim parts section is needed ? not meaning to sound pedantic !
oh also could add
^ GONE
^ GONE
For those whose auto opennign boots are a bit slow or limp get some new gas struts:
8E5 827 552 K
If i recall correctly it was about £60 for a pair but my boot now fires open again!
Also, black optic grille:
8E0 853 651 AF VMZ
Strip below bumper on a saloon; requires painting to body colour for black optic conversions; allows you to paint then fit rather than remove exisiting silver one to paint:
8E5 807 443 GGRY
Also, the part numbers I have for black optic window trims are different to yours but I havent used mine in anger yet so may be wrong. Also, isn't there dirrent part numbers for the Avant? I assume you have given numbers for the saloon?
And lastly for retrofitting the centre armrest I also have a part listed as: N 964 862 04. I think this is a little screw or fixing to fit it on cars that previously didn't have one (less than a £1).
I was copying most of the above from someone's handwriting so I have interpretted as best I can.
8E5 827 552 K
8E0 853 651 AF VMZ
8E5 807 443 GGRY
- TonyHayers
- 5th Gear
Thanks Mike - made additions and clarified re. black optics for saloon. Yeah, I can see the window trim numbers are different to yours. Have you ordered them yet?MikeFish wrote:For those whose auto opennign boots are a bit slow or limp get some new gas struts:
8E5 827 552 K
8E0 853 651 AF VMZ
8E5 807 443 GGRY
^ GONE
^ GONE
A few more(2007 standard vehicle):
Battery Terminal Cover(under bonnet) V8E2 819 422 A0 1C £6.62
Toolbox V8 012 111 A £6.74.
Saloon Boot linings V8E5 863 887 N2 Z3/V8E5 863 J2 Z3 Both £104.84 ex VAT.
Solenoid Valve(for EPC) £54.09.
Clutch hydraulic return tube(sticky clutch) £65.35.
Prices as Feb 2013
And a few more from when I bumped it:
Front Bumper 8EO 807 1055 GP £479.04
L/F Bumper bracket 8E0 807 283E £6.03
Front bumper Clamp Bracket 8E0 098 623 £33.32
Front Grille 8E0 853 651L 3F £196.71
Front badge RS4 8E0 853 736E 2Z £21.82
Bonnet 8E0 823 029E £743.33
Left Headlight Assy £477.30
L/F wing bracket 8E0 821 135D £6.05
Frt Lock carrier 8E0 805 588A £193.76
L/Radiator Air guide 8E0 121 283AA £19.23
Radiator 8E0 121 251AM £281.36
Prices as of Nov 2012 ex VAT.
Richard
Prices as Feb 2013
Richard
Users browsing this forum: No registered users and 111 guests
