Tv tuner?
OskiRs4
Tv tuner?
Post by OskiRs4 » Sat Mar 16, 2013 4:08 am
Hi there, my Rs4 has the usual dvd sd card slotsx2 sat nav etc
I take it they all had this?
Also it has Tv, but it does not work? what could this be?
Do I need to upgrade it?
thanks
sonny
Re: Tv tuner?
Post by sonny » Sat Mar 16, 2013 5:30 am
1)All Sat navs units had the 2 x slots. The Sat Nav/digi pack was a option.
2) No analogue is being broadcast any more. Alternative is to fit a digital receiver for around £600. See Craigyb from here
billq
Re: Tv tuner?
Post by billq » Sat Mar 16, 2013 7:58 am
Anyone know what's involved to covert to a rear cam?
Do I need to do a full cam retrofit or is there a way I can plug a camera into the OEM TV tuner and switch to the camera manually?
OskiRs4
Re: Tv tuner?
Post by OskiRs4 » Sat Mar 16, 2013 5:44 pm
Thanks for the reply
I will leave it for now, I just thought mine was not working correctly, forgot about the switch over to digital,
pDkALO
Re: Tv tuner?
Post by pDkALO » Sat Mar 16, 2013 6:21 pm
When you say it doesn't work - do you mean it switches to TV but then you just get a blank screen / static (which I assume you get due to there being no signal) or do you mean you can only get the CD when you press the CD / TV button?
If it's the latter, that'll be because you haven't got a TV tuner - all RNSe units have the same button, which can cause confusion
Current: Macan Turbo, Boxster 987 S
Gone: RS6 C6 Avant, RS4 B7 Avant, Tamora Speed Six
OskiRs4
Re: Tv tuner?
Post by OskiRs4 » Sat Mar 16, 2013 6:23 pm
Hi thanks for the reply
I am not to sure, its just black?
I will check and post back
