Anyone know these RS6s for sale?
Re: Anyone know these RS6s for sale?
Post by Shoppinit » Tue Feb 26, 2013 7:04 pm
It's not limited to the RS6. Loads of 5HP24/a suffer from it.
Post by chunky79 » Tue Feb 26, 2013 7:06 pm
Sid had a problem with his reverse and it was the selector switch, that threw all the lights up though I think.
Post by Shoppinit » Tue Feb 26, 2013 7:09 pm
That's true, it can be an easy fix. Good point. I should have mentioned that. But I was referring to the lack to drive in reverse problem.
Post by chunky79 » Tue Feb 26, 2013 7:10 pm
Shoppinit wrote:That's true, it can be an easy fix. Good point. I should have mentioned that. But I was referring to the lack to drive in reverse problem.
Whatever. I win, you smell. Unless I have got it wrong!
ant1
Post by ant1 » Tue Feb 26, 2013 7:17 pm
Not quite sure a switch would cause grinding and slipping lads ha ha.
Post by chunky79 » Tue Feb 26, 2013 7:20 pm
Ah, have you mentioned that already then?
Deffo not the switch then. Damn you Shopp.
Post by Shoppinit » Tue Feb 26, 2013 7:23 pm
In yer face, Chumpsy. :bigwave:
Post by chunky79 » Tue Feb 26, 2013 7:28 pm
Tool.
Mr V10
Post by Mr V10 » Wed Feb 27, 2013 3:23 pm
Shoppinit wrote:The reverse problem is a known issue. Can't remember off hand what the fix is, but it's a big job.
An F seal or something iirc.
ant1
Post by ant1 » Wed Feb 27, 2013 7:52 pm
This is the email I got back with the problem. Sound about right?
Oakdene transmissions say it is a small piston at the rear of the box of which the seal perishes, it then looses oil pressure for reverse gear. when the box is cold is reverses fine as the piston seal is tight. we had the oil tested to see if it shoes any other problems and that came back fine.
Post by chunky79 » Wed Feb 27, 2013 8:56 pm
Amar wins. All hail Amar. Problem is the box still has to come out I think. The oil is thicker when cold, that's why it works then.
mattjet1
Post by mattjet1 » Wed Feb 27, 2013 9:32 pm
Mine is for sale, no issues and Audi warranty!
Just a thought...
swannny
Post by swannny » Thu Feb 28, 2013 8:24 am
That reverse gear is what went wrong on the allroad I had. Parked down my drive when I picked it up, in the morning put it in reverse, and nothing, just sat there revving! It's still a gearbox off job, and while it's off might as well get a new tc.
Post by Shoppinit » Thu Feb 28, 2013 9:10 am
swannny wrote:and while it's off might as well get a new tc.
And a new gearbox. The reverse failure is a symptom, not a cause.
swannny
Post by swannny » Thu Feb 28, 2013 9:20 am
Yep, cost me £1500, I'd only owned the car one day!
Always had a lumpy first gear change from cold after that. But once it had changed gear once it was so smooth!
Users browsing this forum: Google Adsense [Bot] and 98 guests
