Any way to improve seat support?
Re: Any way to improve seat support?
Post by Shoppinit » Sun Feb 17, 2013 11:05 am
Post by bam_bam » Sun Feb 17, 2013 11:51 am
Can you only wear those doing a donut, what happens at turn two?
Post by Shoppinit » Mon Feb 18, 2013 8:27 am
Well, I had a good blast in the 6 using the CG-Lock and it's definitely better than nothing. It pulls the lap bit of the belt tight across your lap / waist holding you in the seat pretty well. Obviously the top of your body is free to move around, but you've got the wheel to hold on to. In this respect, unsurprisingly, the 4 point gives more support, but you look like a nonce driving around with a harness on. :) Unless you're on a track, of course.
Post by bam_bam » Mon Feb 18, 2013 9:30 am
I've had a CG lock for some time but I've not fit it. I get the feeling it would munch the belt-loop on the seatbelt tab. Have you noticed any damage?
BillTheButcher
Post by BillTheButcher » Mon Feb 18, 2013 9:39 am
Shoppinit wrote:Well, I had a good blast in the 6 using the CG-Lock and it's definitely better than nothing. It pulls the lap bit of the belt tight across your lap / waist holding you in the seat pretty well. Obviously the top of your body is free to move around, but you've got the wheel to hold on to. In this respect, unsurprisingly, the 4 point gives more support, but you look like a nonce driving around with a harness on. :) Unless you're on a track, of course.
Thanks for the update. :)
It sounds like it won't do what we need.
Post by Shoppinit » Mon Feb 18, 2013 9:40 am
I tried it on the M3 first and that has got a curved belt-loop thing and the CG-Lock didn't want to lock onto it properly. On the 6 the belt-loop is flat and has a little recess as if it was designed specifically for the CG-lock. No doubt that tightening it up will mark the plastic though. It has on the M3 because I tightened it up like a barsteward and it still wasn't locked on securely. On the Audi I didn't take it off, but it will have marked the plastic for sure. I'm not bothered because it's not visible unless you are specifically looking for it.
Post by Shoppinit » Mon Feb 18, 2013 9:42 am
BillTheButcher wrote: It sounds like it won't do what we need.
If you want to know what the CG-lock will be like, pull the belt tight across your missus's lap and get her to keep tugging it so that it presses her down in the seat. Then drive around like a maniac and see if she feels more secure. If not, then the CG-lock will be no good for you. I think it will make a big difference, though.
Daveperc
Post by Daveperc » Mon Feb 18, 2013 9:45 am
Can you resort to "normal mode" of belt operation if carrying a different passenger etc, or does it stay fixed.?
Dave
Post by Shoppinit » Mon Feb 18, 2013 9:48 am
You can pull the tab off and it acts just like a normal belt without you having to remove the CG-Lock.
Daveperc
Post by Daveperc » Sat Feb 23, 2013 9:13 am
Mine arrived yesterday and fitted in 5 mins.
Did 150 miles down to Dorset and back but hard to say how much difference it made. Have to do something more energetic on some twisties to really tell!! :FIREdevil:
Dave
BillTheButcher
Post by BillTheButcher » Sat Feb 23, 2013 6:35 pm
Car sold today to Sulli on here so it's his problem now. :lol:
RS6JJL
Post by RS6JJL » Sat Feb 23, 2013 8:41 pm
I've got a CG Lock on my rs6 love it, really holds you in tight
KV53 YML - RS6 Avant - Stolen Hampshire
RS 51X CS - RS6 Avant - Sold
Users browsing this forum: Google [Bot], Shoppinit and 118 guests
