Sputter on start up?
Keaney
Post by Keaney » Fri Jan 25, 2013 10:08 am
The last few times I've started the car up from cold it's started fine but seems to sputter a little before putting the revs into the normal high idle.
Vagcom has not revealed anything so I'm just wondering if I should give a little gas on cold mornings or if there's something I should be checking?
Any help appreciated
A7 3.0T - Pretty Std at the moment... in warranty
VW Caddy 2k 1.9 TDI - Std
Has beens:
C5 RS6 Avant - Wagbo'd, PSS9, MiIltek Res, MRC Stage 2, ACE Torque Converter, 551ps 815nm | 00 B6 A4 2.5TDI | 01 Nissan R34 GTR V-Spec (UK) | 93 Toyota MR2 GT | 95 Mitsubishi FTO | BMW 318is | Vauxhall Corsa 1.4 16v SRI | Vauxhall Nova 1.3SR Chavtastic
MaQQu
Re: Sputter on start up?
Post by MaQQu » Fri Jan 25, 2013 10:42 am
Check engine coolant temperature sensor or ignition coils.
Post by Shoppinit » Fri Jan 25, 2013 10:44 am
Could be a leaky injector. Or a dodgy sensor.
Before starting from cold, check your recorded trim values, and all the values from the temp sensors. Air and coolant.
Might be an air leak. Or heavy drain on the alternator. Try starting with the air con off and headlights, etc off. See if that makes a difference.
/Check your MAF readings when it's spluttering, too. THen at normal idle.
Post by bam_bam » Fri Jan 25, 2013 10:56 am
Shoppinit wrote:Could be a leaky injector. Or a dodgy sensor.
Unhelpful prick.
Keaney
Post by Keaney » Fri Jan 25, 2013 7:44 pm
Thanks fellas, It may be my coolant sensor but I have topped my coolant up this week thinkin the sensor could be on its way out.
Shop what do I need to log on vag specifically... I'm not to savvy with it after the fault checks but can prob work it out if its in front of me
Has beens:
Post by Shoppinit » Fri Jan 25, 2013 7:54 pm
Keaney wrote:log on vag
*snigger*
Nothing to do with your coolant level. Temperature is what we're interested in. Specifically whether the values are coherent or wonky. Go to advanced measuring blocks and find it in there. I'm not going to explain how to use vagcom, you're gonna have to find someone more patient than me, or use google.
http://www.ross-tech.com/vcds/tour/adv-meas-blocks.html
Post by Shoppinit » Fri Jan 25, 2013 8:02 pm
Coolant,Temperature (G62)
Mass Air Flow,(G70) Bank 1
Mass Air Flow,(G246) Bank 2
Engine Speed,(G28)
Intake Air,Temperature (G42)
Throttle Valve Angle
That should do for starters. Log in turbo mode if you can.
Post by bam_bam » Fri Jan 25, 2013 8:04 pm
Impatient and unhelpful prick.
Keaney
Post by Keaney » Fri Jan 25, 2013 8:08 pm
No that's spot on Shop thanks for your help
Has beens:
swannny
Post by swannny » Fri Jan 25, 2013 11:07 pm
bam_bam wrote:Impatient and unhelpful prick.
Everytime I read your posts bam, I automatically picture jack dee saying them in his dry wit way!
Post by bam_bam » Sat Jan 26, 2013 12:17 am
That's how it sounds in my head too.
Users browsing this forum: srichards and 55 guests
