TerraClean RS4 test (FAIL FAIL FAIL)
stu
Re: TerraClean RS4 test: LIVE(ish)
Post by stu » Fri Jan 18, 2013 12:38 pm
That one from october probably had a flexible end, just like the endoscopes they use in Ear Nose Throat to go up your nose and down to the vocal chords. Not cheap. Do most engine boroscopes do this?
Gizmo68
Post by Gizmo68 » Fri Jan 18, 2013 12:41 pm
Not all no, some however have the camera at 90º
VCDS HEX+CAN owner - covers all VAG cars (PM me if you require VCDS coding in Kent)
TonyHayers
Post by TonyHayers » Fri Jan 18, 2013 1:00 pm
Yeah, we tried with their borescope but it's just a bendy one (technical term). Tried for 40 mins to get it to bend up the cylinder but nope just got a very nice view of the shape of the top of the piston :(
06 Phantom Black Saloon:
^ GONE :cry:
TonyHayers
Post by TonyHayers » Fri Jan 18, 2013 1:10 pm
Ok, first dyno results. They waited until we had 2 near identical runs.
Apologies for the dodgy photo, I don't have a scanner on me.
^ GONE :cry:
Timster
Post by Timster » Fri Jan 18, 2013 1:19 pm
Wow, those figures do look low.
I think any clean will give good results on those.
BTW, I have a feeling that Costco (yes you read that right), do a bendy borescope.
Good effort for doing this and posting it.
'R'e'S'pect_4
Post by 'R'e'S'pect_4 » Fri Jan 18, 2013 1:43 pm
Be good to see the results Tony.
you sure are getting through your 'to-do' list in your sig! LOL :wink:
TonyHayers
Post by TonyHayers » Fri Jan 18, 2013 1:44 pm
'R'e'S'pect_4 wrote:Be good to see the results Tony.
Aye, got my x-pipe getting fitted Monday too :)
^ GONE :cry:
sonny
Post by sonny » Fri Jan 18, 2013 1:52 pm
Nice one Tony, thanks for sharing.
Did you do a vacuum check prior to dyno run?
TonyHayers
Post by TonyHayers » Fri Jan 18, 2013 2:11 pm
sonny wrote:Nice one Tony, thanks for sharing.
Hrm, no, got a howto - or do I need VCDS for that? I won't do anything about it now though so as not to mess with comparison. But does sound like I'm pretty low to start with. Lad at RStuning said it wasn't the lowest he'd seen though - they had one do 330 the other week apparently.
^ GONE :cry:
TonyHayers
Post by TonyHayers » Fri Jan 18, 2013 2:15 pm
FAIL FAIL FAIL.
This is a disaster of a test. They decided they can't actually do the terraclean. Fuse for fuel pump disables ignition (immobiliser?) so can't get car to run without disconnecting fuel pump itself, which they are convinced will mean taking fuel tank off. :bash:
Sorry to everyone for wasting your time.
Gonna go and punch a wall or something after wasting half a day on this. Over and out.
^ GONE :cry:
Brooner
Post by Brooner » Fri Jan 18, 2013 2:19 pm
thats a shame you would think these guys would look in to the technical issues before they said to you they could do it
TonyHayers
Post by TonyHayers » Fri Jan 18, 2013 2:33 pm
Brooner wrote:thats a shame you would think these guys would look in to the technical issues before they said to you they could do it
Yeah :/ The owner said that sometimes it takes a bit of fiddling to find the right places to plug into the fuel lines but just now told me they had a TTRS in the other day that they couldn't do for the same reason. *Sigh*.
The photos of the place on the website are a little deceiving to say the least.
^ GONE :cry:
murph7355
Post by murph7355 » Fri Jan 18, 2013 2:34 pm
How do they rig this system up then?
Sounds very bizarre to me.
Did you tell them you were doing independent before and after tests :-)
TonyHayers
Post by TonyHayers » Fri Jan 18, 2013 2:40 pm
murph7355 wrote:How do they rig this system up then?
The machine replaces the fuel supply while it runs, so the machine plugs into the fuel supply and the return so the car runs off the system until the cans of the product are gone. It's pressurised to match the pressure of the fuel pump and burns the modified terraclean fuel from the machine... blah blah... no hydrocarbons... blah blah... arophatics... blah blah... aromatics... blah blah... negatively charged particles... blah blah...
^ GONE :cry:
Brooner
Post by Brooner » Fri Jan 18, 2013 3:20 pm
Wouldn't be happy with them wasted your time would be giving the owner a fecking telling about promoting a product they don't fully know how to use on your car after fill you full of <beep> about the benifits of it when they can't even hook it up
Users browsing this forum: Google Adsense [Bot] and 345 guests
