TerraClean RS4 test (FAIL FAIL FAIL)
TonyHayers
Post by TonyHayers » Fri Jan 18, 2013 9:42 am
Ok, hopefully this should be interesting. I'm going to do a bit of a trial of the TerraClean carbon cleaning system today on my RS4. I'll be updating this post throughout the day with results and photos.
I'm not really pretending that this is going to be a scientific experiment, but I'm going to do my best to get an accurate idea as possible as to the effectiveness of the TerraClean system on our engines. I am pretty skeptical that this will make a dramatic difference tbh not least after speaking to one of the main engineers in the UK! It seems, so far, that any time you ask TerraClean for some evidence of the results that have been achieved - they simply refer to it's scientific heritage (something about Canada) or refer to anecdotal evidence about how happy customers are.
TerraClean makes some pretty bold claims, but I'm yet to see any real evidence that it will make any difference to our V8s since there seems to be some consensus that the carbon buildup on the intake ports is due to the valve overlap designed for EGR, rather than being due to oil vapour/PCV (the empty catch cans that several owners have, being a strong indication).
This is my plan:
1) Check oil/water/fuel level
2) Get car warmed up to operating temperatures
3) RSTuning, Leeds (9.30am):
- Borescope "before" inspection (photos)
- First dyno run
- Check & record results
4) TerraClean agent, Leeds:
- Emissions "before" test
- Terraclean (2 hours?)
- Emissions "after" test
5) RSTuning, Leeds:
- Borescope "after" inspection (photos)
- Second dyno run
- Check/record results
Let's see what happens :)
06 Phantom Black Saloon:
^ GONE :cry:
Audi Pardner
Re: TerraClean RS4 test: LIVE(ish)
Post by Audi Pardner » Fri Jan 18, 2013 9:46 am
Interesting; look forward to the results.
barryrs
Post by barryrs » Fri Jan 18, 2013 10:22 am
Im also pretty sceptical of the Terraclean system making a difference but I think its great that you are making the effort to settle it once and for all Tony. Image
Brooner
Post by Brooner » Fri Jan 18, 2013 10:31 am
Very interested to see your resluts
Jonah
Post by Jonah » Fri Jan 18, 2013 10:42 am
Brooner wrote:Very interested to see your resluts
I know he's from Leeds, but there is no need for that.
The_Coat
Post by The_Coat » Fri Jan 18, 2013 10:45 am
Will be keeping an eye on this
RS4 Avant - Misano Red
murph7355
Post by murph7355 » Fri Jan 18, 2013 10:46 am
Good effort. Will be interesting to see the results.
Gizmo68
Post by Gizmo68 » Fri Jan 18, 2013 11:01 am
Hats off to you Tony for doing this properly, I too am sceptical about the claims …. but I would be delighted to be proved wrong. :beerchug:
VCDS HEX+CAN owner - covers all VAG cars (PM me if you require VCDS coding in Kent)
Brooner
Post by Brooner » Fri Jan 18, 2013 11:27 am
long day 2 hrs sleep in 40
andre3k
Post by andre3k » Fri Jan 18, 2013 11:35 am
Interesting.
I applaud the methodology, very clean. No real cause to argue whatever the results are.
Gavla
Post by Gavla » Fri Jan 18, 2013 11:41 am
I was tempted by them after watching this on TV - I contacted them through FB and also expressed my concerns over the effectiveness with the FSI engine. They claimed it would work here's some of the feedback I received....
"I have had a response from one of our technical guys re your engine. We are aware that the FSI engine is particularly prone to carbon build up. We have done 2 vehicles with this engine for the very well respected Frank and David Massey (well known technical trainers with in the automotive industry). In both cases the results were fantastic and this prompted them to invest in the technology for their own buisiness Automotive Diagnostic Solutions in Preston. I am reliably informed that TerraClean does reach the areas of this particular engine most prone to build up."
:drink:
We will see....... well done Tony :thumbs:
RS4 (B7) Saloon Phantom Black, Black Optics, Tech Pack, KW Lowering Spring Kit, Stern Adjustable Arms, MRC Stage 2, Stage 1 Manifold, CAF, LOBA Stage 1 Clutch,
447ps/490nm (MRC), Scorpion Exhaust Non-Res Black Tips, Pre-cats gutted, Shadow Black Chrome Alloys, Viper Alarm, LED Interior lights, Tints
adsgreen
Post by adsgreen » Fri Jan 18, 2013 11:51 am
Gavla wrote:David Massey (well known technical trainers with in the automotive industry).
I think I know David Massey - IIRC correctly he is a technical author and for example wrote all the workshop manuals for Lotus cars.
(might be different bod though)
Post by MikeFish » Fri Jan 18, 2013 11:54 am
Good one!
Looking forward to see the outcome.
Come on Tony, havent you got first dyno run yet?
TonyHayers
Post by TonyHayers » Fri Jan 18, 2013 11:57 am
Ok, first dyno test done. First blow to my plan too, the tuning guys were convinced there was no point trying to bore scope through plug socket as we wouldn't be able to get a view of the back of the valves :/
Will post initial dyno results shortly.
^ GONE :cry:
Gizmo68
Post by Gizmo68 » Fri Jan 18, 2013 12:02 pm
Tony, show them this post and it is apparent that it will be useful:
don wrote:
adsgreen wrote:This is a great example of what I mean.
http://forum.rs246.com/viewtopic.php?f= ... th#p546640
Hell of a lot cheaper than manifold off and would give a good benchmark.
Wow that is an amazing effect! :shock: The first I have heard of it but a simple solution of injecting a water/methanol mix in the intake. I thought that was just something that people used for hooning or at the drag races. Alcohol and water are really good solvents so no reason why it wouldn't work and looks like it does. Though some (Audi) may not like the idea of injecting methanol and water into the engine so warranties may be concern though as I understand it if done properly there is no harm to the engine. It's also not quite clear what ratio of water to methanol he used but for cleaning purposes it presumably does not have to be as high as the 50:50 mix at the races.
before:
after:
Users browsing this forum: Google Adsense [Bot] and 133 guests
