RS6 C5 Phaeton 6.0 W12 Rear Disc Brake Rotor Installation
skirs6
Re: RS6 C5 Phaeton 6.0 W12 Rear Disc Brake Rotor Installatio
Post by skirs6 » Mon Dec 31, 2012 1:32 pm
Can you skim drilled ventilated discs or just standard solid ones???????
RS626
Post by RS626 » Mon Dec 31, 2012 1:44 pm
Mine are drilled and ventilated and have been skimmed - they work just fine!
2003 RS6 Avant Mugello blue
2007 A6 2.7 Avant Le Mans grey
1963 Jaguar British Racing Green Triumph GTR4 Dove
skirs6
Post by skirs6 » Mon Dec 31, 2012 6:13 pm
Good to know thanks :thumbs:
Post by chunky79 » Mon Dec 31, 2012 10:33 pm
Just make sure they don't go below min thickness.
Mr V10
Post by Mr V10 » Thu Jan 17, 2013 12:33 pm
Would these work?
http://www.eurocarparts.com/ecp/c/Volks ... 832&000027
The dimensions are slightly different from what the OP mentions.
Re:
Post by Shoppinit » Thu Jan 17, 2013 4:14 pm
This:
grizz wrote:The disc is all steel so weigh more ..All the rs's have a alloy centre to keep weight down.. It's a cheap fix but not ideal.
Mr V10
Post by Mr V10 » Thu Jan 17, 2013 4:30 pm
Good, will balance out all that weight at the front. Ordered a set, £77 for in total and that includes delivery. I needed them done by tomorrow.
seaneb
Post by seaneb » Fri Jan 18, 2013 12:28 am
Mr Footlong wrote:With £570-odd spent on my fronts that I only did just under 4000 "XP-10" miles on, I was only happy to sell them on to somebody else after getting them skimmed. Worth doing after having those pads biting down on them like rabid dogs.
I CANNOT recommend highly enough that people seriously weight up the pros and cons of the horribly air-restrictive front disc guards on these. In my experience on this car, they cause the inner side of the disc to heat up far more than that free outer side, the holes in the + disc inner sides clog up far worse and the dist just gets packed in there with nowhere to go compared to the outer sides due to no flaming air really getting to the inner disc face. I took mine off and they are NEVER going back on.
There is also Unit 20's Pheaton front disc ducting mod to consider of course.
This is interesting Mr Footlong. Both my front discs are excessively worn on the inside faces and according to service history they are only 3000 miles old. Unit 20 have advised me that they will need replacing with next pad change (which wont be long I expect).
Seriously considering doing the same.
How long ago did you do this if you dont mind me asking and have you noticed any bad side effects?
PREVIOUS: Black Audi B6 S4 Avant. Custom exhaust (sounded amazing). Otherwise standard and near perfect.
PRESENT: Muggy '53 RS6 loon. MTM Stage2. KW3s. 100 cells. Milltek.
bilko1
Post by bilko1 » Fri Jan 18, 2013 1:27 am
Amar wrote:Good, will balance out all that weight at the front. Ordered a set, £77 for in total and that includes delivery. I needed them done by tomorrow.
You give Amanda grief for fitting Bridgestones but you are fitting cheap inferior discs :bash: what is wrong with you Amar? Don't you love your plus anymore?
Mr V10
Post by Mr V10 » Fri Jan 18, 2013 8:16 am
Bilko. I've just bought this C6 RS6, that wasn't cheap so in addition to not feeling as flush as normal I needed the discs next day so these will be better vs the worn ones on there now. I hope I never have to replace one of these 420mm bad boy ceramics. :shock:
Post by Shoppinit » Fri Jan 18, 2013 9:19 am
I've been without splash guards since I put my big brakes on. No detrimental effect that I can see.
bilko1
Post by bilko1 » Fri Jan 18, 2013 12:24 pm
Amar wrote:Bilko. I've just bought this C6 RS6, that wasn't cheap so in addition to not feeling as flush as normal I needed the discs next day so these will be better vs the worn ones on there now. I hope I never have to replace one of these 420mm bad boy ceramics. :shock:
Are you selling your C5 or saving up for a C7 so you have a full house :bigblink:
Mr V10
Post by Mr V10 » Fri Jan 18, 2013 1:09 pm
The C5 will go as the C6 will do everything better, bar noise... But then again, I've not heard a C6 properly...
Users browsing this forum: asgor, Google [Bot] and 83 guests
