Engine cutout won't restart
Nemesismoo
Post by Nemesismoo » Thu Jan 10, 2013 10:05 pm
Tonight on my way home from work My RS6 cutout & won't restart :roll:
Engine turns over - probably a bit faster than normal but just will not start - after a while of cranking Engine oil level warning comes up.
Was thinking fuel related - pump / relay maybe as turning faster than normal.
Re: Engine cutout won't restart
Post by MikeFish » Thu Jan 10, 2013 10:10 pm
Did you stop a bit suddenly or hit a big bump? I assume these audi have fuel cut off valves which turn cut off the fuel supply electronically?
All my old cars used to have them hidden in the car and would need resetting before the car would start again. Obviously if you stop a bit to sharpish it should activate it but you never know. Always handy to know where they are on your car.
Nemesismoo
Post by Nemesismoo » Thu Jan 10, 2013 10:21 pm
Had just gone over a speed bump, so not sure???
Post by MikeFish » Thu Jan 10, 2013 10:51 pm
Ok, a little delving online and it seems that on audis with airbags the fuel cut off will only kick in when the airbag is deployed so I don't think that is your problem.
Nemesismoo
Post by Nemesismoo » Thu Jan 10, 2013 11:14 pm
Ah right - well its not that then, think I might have noticed that. Thanks for looking though :-)
el_ringo
Post by el_ringo » Thu Jan 10, 2013 11:42 pm
Enough fuel in it? The gauge is a know liar and could be dead
Daytona Grey (C5) RS6 saloon, but just a little better...
**** SOLD!!! :( ****
KW V3 suspension
390mm C6 Brakes
Hotchkis ARBs
Viper Tuning (537bhp 604lbft)
Unit 20 TCU remap
Milltek non-res exhaust and downpipes
100 cell sport cats
Aero wipers
Winter wheels
Wagner intercoolers
LED interior lights
Tesla Model S 85D
All the options with the exception of stupid air suspension
Tesla Model X 60D
Silly doors and all!
Nemesismoo
Post by Nemesismoo » Thu Jan 10, 2013 11:54 pm
el_ringo wrote:Enough fuel in it? The gauge is a know liar and could be dead
Loads in it - £70 yesterday & done about 4 miles since
ElevenSec
Post by ElevenSec » Fri Jan 11, 2013 12:14 am
Nemesismoo wrote:Tonight on my way home from work My RS6 cutout & won't restart :roll:
Don't like the fact that the Engine turns over faster than normal. That could be the sign of a Failed Timing Belt. Hope not as that could be catastrophic.................
03 RS6 Saloon. Full Catless Milltek (Roars). ViperTune ECU. MTM(soon to be Viper) TCU. H&R Coilovers. Hotchkiss ARB's. 19X10" Wheels with 275-30-19" Rubber at each corner. V1 Radar Locator.
Nemesismoo
Post by Nemesismoo » Fri Jan 11, 2013 12:16 am
:shock: Hope not, was only changed 8K ago :thumbsdown:
Post by MikeFish » Fri Jan 11, 2013 1:37 am
I've heard loads of engines turn faster than normal over the years and never anything serious so wouldn't let that bit worry you.
ElevenSec
Post by ElevenSec » Fri Jan 11, 2013 1:52 am
[ :shock: Hope not, was only changed 8K ago :thumbsdown:[/quote]
Since it was changed only 8K ago, then the Cam belt shouldn't be an issue, but you never know. Hope it turns out to be something simple such as a fuel pump or an ECU. To really find out you will have to VAG it with a Ross Tech and see what Fault Codes you come up with.......
Post by chunky79 » Fri Jan 11, 2013 7:50 am
Is the immobiliser light flashing? Can't remember if it cuts the fuel or start out.
What fuel did you put it?
Wait for Shopp to wake up.
Ooooooo, another thought. How about checking the wiring under the scuttle cover. Had a car on here last week that lost power due to the wiring being corroded, perhaps you have a fault there with a particular wire?
mavada
Post by mavada » Fri Jan 11, 2013 7:55 am
chunky79 wrote:Is the immobiliser light flashing? Can't remember if it cuts the fuel or start out.
:thumbs:
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Post by Shoppinit » Fri Jan 11, 2013 8:07 am
Could be lots of things. You need to get a Vagcom / obd2 diagnostics on it.
Crank position sensor seems to be a common one.
Nemesismoo
Post by Nemesismoo » Sun Jan 13, 2013 10:15 pm
Cars in garage now audi/bmw/merc specialists so just waiting to hear from them now......
Have only had the car 2 weeks as well :oops:
Users browsing this forum: audirew and 74 guests
