Engine turns over - probably a bit faster than normal but just will not start - after a while of cranking Engine oil level warning comes up.
Was thinking fuel related - pump / relay maybe as turning faster than normal.
Loads in it - £70 yesterday & done about 4 miles sinceel_ringo wrote:Enough fuel in it? The gauge is a know liar and could be dead
Nemesismoo wrote:Tonight on my way home from work My RS6 cutout & won't restart![]()
ElevenSec wrote:Nemesismoo wrote:Tonight on my way home from work My RS6 cutout & won't restart![]()
Don't like the fact that the Engine turns over faster than normal. That could be the sign of a Failed Timing Belt. Hope not as that could be catastrophic.................
chunky79 wrote:Is the immobiliser light flashing? Can't remember if it cuts the fuel or start out.
What fuel did you put it?
Wait for Shopp to wake up.
Ooooooo, another thought. How about checking the wiring under the scuttle cover. Had a car on here last week that lost power due to the wiring being corroded, perhaps you have a fault there with a particular wire?
