Door Handle Problems
Re: Door Handle Problems
Post by Shoppinit » Thu Jan 10, 2013 1:51 pm
The door trim comes off really easily.
bilko1
Post by bilko1 » Thu Jan 10, 2013 3:01 pm
Shoppinit wrote:The door trim comes off really easily.
Once you have found the little hole under the window switch it is :nodder:
mavada
Post by mavada » Thu Jan 10, 2013 3:23 pm
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
WAFWOTTBI
Post by WAFWOTTBI » Thu Jan 10, 2013 5:53 pm
Have same problem with drivers door,but at present can't get door to open at all...will try again this weekend,can't take door trim off to have a gander until i get door open....... WAFFY :blackrs4:
RS 6 Avant,
Ebony black mettallic,03 plate,
H&R coilovers,
miltek back boxes,
pirelli p zero's,
Post by Shoppinit » Thu Jan 10, 2013 6:08 pm
Good link, MAV. I'm gonna put it in the FAQ.
Where do I know that car from? It it Eddie's?
ChrisRS6
Post by ChrisRS6 » Thu Jan 10, 2013 9:37 pm
If it's that easy to remove the door trim, then I'll have a crack at this shortly.
Not sure I'll know what I'm looking at once it's off though. Will probably check everything is done up properly and lube up any parts which are supposed to move.
03 Missano Red Avant
85k miles
RustyBucket
Post by RustyBucket » Thu Jan 10, 2013 10:01 pm
Not had precisely your symptoms, but I have had to have a door lock replaced on both of mine - had one done last night! New lock is £123 and about an hour to fit. In both cases it was the internal latch mechanism that was basically worn out.
Slightly different but my passenger door lock is pretty much worn and keeps bouncing off the latch and needs replacing. Where did you get the lock done on yours Dave?
ChrisRS6
Post by ChrisRS6 » Sun Mar 24, 2013 5:03 pm
Door card does come off really easily. I couldn't see anything broken or loose in there. Squirted a bit more lube around the mechanism while I had access but this didn't seem to cure the problem.
Put up with it for a while but was becoming more of a constant problem rather than intermittent.
Got the Audi dealers to fit a new lock mechanism the other day and it has been fine since.
Part number on the invoice looks like A402 837 016 039058/Door Lock if this helps anybody else. Was the driver's side one.
85k miles
Post by chunky79 » Sun Mar 24, 2013 5:31 pm
How much did they charge you Chris?
bilko1
Post by bilko1 » Mon Mar 25, 2013 12:22 am
chunky79 wrote:How much did they charge you Chris?
I bet he's still sore :bigblink:
Post by chunky79 » Mon Mar 25, 2013 7:37 am
It's useful to know when the topic is bought up again. I would have said around 1 1/2 hours labour.
ChrisRS6
Post by ChrisRS6 » Mon Mar 25, 2013 10:04 am
Haha - it was the usual level of charges you would expect from Audi.
£120.77 for the part and not sure about the labour part as I had a few other things done at the same time.
Guess it worked out to be around £150 for labour ish.
85k miles
Daveperc
Post by Daveperc » Mon Mar 25, 2013 6:05 pm
Should be an hour max to fit IIRC
Keaney
Post by Keaney » Wed Apr 16, 2014 5:58 pm
Anyone got the part number for the plastic but that wears on the push rod?
A7 3.0T - Pretty Std at the moment... in warranty
VW Caddy 2k 1.9 TDI - Std
Has beens:
C5 RS6 Avant - Wagbo'd, PSS9, MiIltek Res, MRC Stage 2, ACE Torque Converter, 551ps 815nm | 00 B6 A4 2.5TDI | 01 Nissan R34 GTR V-Spec (UK) | 93 Toyota MR2 GT | 95 Mitsubishi FTO | BMW 318is | Vauxhall Corsa 1.4 16v SRI | Vauxhall Nova 1.3SR Chavtastic
amanda1
Post by amanda1 » Wed Apr 16, 2014 7:03 pm
Mines had new locks as well which sorts the prob ;)
950 nm torque!
Users browsing this forum: bilko1 and 553 guests
