Think I'm done :( [UPDATE: or maybe not]
RIV
Re: Think I'm done :(
Post by RIV » Fri Dec 28, 2012 2:42 pm
Get it fixed Toney, you will be chuffed to bits with it once sorted, from what PG has told me the gen 2 DRC is much more reliable :thumb:
stu
Post by stu » Fri Dec 28, 2012 3:15 pm
So that's that. The RS246 hive mind has decided!!
Who's next?
TonyHayers
Post by TonyHayers » Fri Dec 28, 2012 3:26 pm
stu wrote:So that's that. The RS246 hive mind has decided!!
Who's next?
Haha, are you all chipping in too? ;)
06 Phantom Black Saloon:
^ GONE :cry:
Audi Pardner
Post by Audi Pardner » Fri Dec 28, 2012 4:46 pm
Just to perpetuate this thread, is the gen 2 DRC referred to by Silas above the second generation of dampers supplied by Audi?
Without repeating an earlier thread of mine in full and boring everyone, 3 dampers were replaced on my car under the 'goodwill' scheme in 2010 (before I owned it) and now the other one looks to have gone. Are the replacement dampers likely to last longer than the originals ie did Audi resolve the problem, or is this an inevitable repair every few years that might warrant going over to conventional struts?
TonyHayers
Post by TonyHayers » Fri Dec 28, 2012 5:21 pm
Audi Pardner wrote:Just to perpetuate this thread, is the gen 2 DRC referred to by Silas above the second generation of dampers supplied by Audi?
When they say "gen 2" I believe they're referring to the revision "b" damper part numbers e.g 8E0 412 020 B / 8E0 412 019 B.
^ GONE :cry:
grizz
Post by grizz » Fri Dec 28, 2012 7:24 pm
I'm open tomorrow and monday , then back to normal on the 2nd .
I have 3 tdi loan cars so it'll next to nothing in fuel ..
Unit 20
0151 3366888
P_G
Post by P_G » Fri Dec 28, 2012 7:44 pm
If you are being technical about it they are actually Gen III because the C5 RS6 DRC was first, but they are the second upgrade version of the B7 RS4 DRC damper. To date as far as I have read, no one has had Gen II failure unless not properly fitted / pressurised. And when I say properly fitted not all Audi franchises have the RS4 DRC pressurisation tool and try to use the one they have for the C5 RS6 which does work but not properly.
I had my fronts replaced at 32k miles with the uprated versions and sold at 99k miles 4 years later with zero issues if that gives you some confidence in them.
Audi Pardner
Post by Audi Pardner » Fri Dec 28, 2012 8:01 pm
Thanks P-G, I'll ask the main dealer if they have the correct RS4 pressurisation tool before they do any work.
TonyHayers
Post by TonyHayers » Sat Dec 29, 2012 11:21 am
grizz wrote:I'm open tomorrow and monday , then back to normal on the 2nd .
I phoned you just now but they said you weren't in til Monday, was going to try to bring it over today.
^ GONE :cry:
Mr V10
Post by Mr V10 » Sat Dec 29, 2012 12:06 pm
Or, if your name's Amar, the A Team van. :jump_clap:
RS4pete
Think I'm done :(
Post by RS4pete » Sat Dec 29, 2012 12:32 pm
Sorry to hear you're still having issues! Very good advice and great to see you're taking it.
Once it's sorted properly you'll absolutely love it!!
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit :)
TonyHayers
Post by TonyHayers » Sat Dec 29, 2012 3:09 pm
RS4pete wrote:Sorry to hear you're still having issues! Very good advice and great to see you're taking it.
Thanks mate. Giving it one last shot, see what unit20 say, if it's not too bad then I'll just do it and keep it for a while at least. If it's gonna cost too much then I'll just leave it and part-ex and cut my losses.
Just really gutting to have it all "done" (£1300-worth) and then realise it's worse than before! I've put a lot into this car since I've had it, fixing little bits and pieces (bit like a restoration!).
^ GONE :cry:
spikeyboy101
Post by spikeyboy101 » Sat Dec 29, 2012 3:29 pm
Wise advise from others on here. Hope you get it sorted.
Curious by the comment of getting the RAC to pick the car up, I'm over 250 miles away from unit 20 so a bit of a pain to get to if I have DRC issues (hope I'm not tempting fate)
Do the RAC offer this service ? How do you go about getting it ?
I have full green flag cover under my bank account, would this fall under the take to nearest dealer to fix ?
grizz
Post by grizz » Sat Dec 29, 2012 4:42 pm
spikeyboy101 wrote:Wise advise from others on here. Hope you get it sorted.
Not sure if the RAC Do but with the AA they will with there relay service ..
Unit 20
0151 3366888
TonyHayers
Post by TonyHayers » Sat Dec 29, 2012 4:45 pm
Yeah, you need the "Recovery" option with RAC it looks like: "We'll take you, up to 7 passengers and your car to your chosen destination anywhere in mainland UK."
^ GONE :cry:
Users browsing this forum: Bing [Bot], Google Adsense [Bot], Zyox and 435 guests
