Think I'm done :( [UPDATE: or maybe not]
Re: Think I'm done :(
Get it fixed Toney, you will be chuffed to bits with it once sorted, from what PG has told me the gen 2 DRC is much more reliable
So that's that. The RS246 hive mind has decided!!
Who's next?
Who's next?
- TonyHayers
- 5th Gear
Haha, are you all chipping in too?stu wrote:So that's that. The RS246 hive mind has decided!!
Who's next?
06 Phantom Black Saloon:
^ GONE
^ GONE
Audi Pardner
Just to perpetuate this thread, is the gen 2 DRC referred to by Silas above the second generation of dampers supplied by Audi?
Without repeating an earlier thread of mine in full and boring everyone, 3 dampers were replaced on my car under the 'goodwill' scheme in 2010 (before I owned it) and now the other one looks to have gone. Are the replacement dampers likely to last longer than the originals ie did Audi resolve the problem, or is this an inevitable repair every few years that might warrant going over to conventional struts?
Misano Red B7 RS4 Avant. 20" Rotors. KW adjustable spring kit. 8 & 10mm H&R spacers. MRC Stage 2 remap. Pre-cat delete & x-pipe.
- TonyHayers
- 5th Gear
When they say "gen 2" I believe they're referring to the revision "b" damper part numbers e.g 8E0 412 020 B / 8E0 412 019 B.Audi Pardner wrote:Just to perpetuate this thread, is the gen 2 DRC referred to by Silas above the second generation of dampers supplied by Audi?
^ GONE
^ GONE
I'm open tomorrow and monday , then back to normal on the 2nd .
I have 3 tdi loan cars so it'll next to nothing in fuel ..
Unit 20
0151 3366888
0151 3366888
If you are being technical about it they are actually Gen III because the C5 RS6 DRC was first, but they are the second upgrade version of the B7 RS4 DRC damper. To date as far as I have read, no one has had Gen II failure unless not properly fitted / pressurised. And when I say properly fitted not all Audi franchises have the RS4 DRC pressurisation tool and try to use the one they have for the C5 RS6 which does work but not properly.Audi Pardner wrote:Just to perpetuate this thread, is the gen 2 DRC referred to by Silas above the second generation of dampers supplied by Audi?
I had my fronts replaced at 32k miles with the uprated versions and sold at 99k miles 4 years later with zero issues if that gives you some confidence in them.
Audi Pardner
Thanks P-G, I'll ask the main dealer if they have the correct RS4 pressurisation tool before they do any work.
- TonyHayers
- 5th Gear
I phoned you just now but they said you weren't in til Monday, was going to try to bring it over today.grizz wrote:I'm open tomorrow and monday , then back to normal on the 2nd .
^ GONE
^ GONE
Or, if your name's Amar, the A Team van.grizz wrote:I'm open tomorrow and monday , then back to normal on the 2nd .
Think I'm done :(
Sorry to hear you're still having issues! Very good advice and great to see you're taking it.
Once it's sorted properly you'll absolutely love it!!
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit
- TonyHayers
- 5th Gear
Thanks mate. Giving it one last shot, see what unit20 say, if it's not too bad then I'll just do it and keep it for a while at least. If it's gonna cost too much then I'll just leave it and part-ex and cut my losses.RS4pete wrote:Sorry to hear you're still having issues! Very good advice and great to see you're taking it.
Just really gutting to have it all "done" (£1300-worth) and then realise it's worse than before! I've put a lot into this car since I've had it, fixing little bits and pieces (bit like a restoration!).
^ GONE
^ GONE
spikeyboy101
Wise advise from others on here. Hope you get it sorted.
Curious by the comment of getting the RAC to pick the car up, I'm over 250 miles away from unit 20 so a bit of a pain to get to if I have DRC issues (hope I'm not tempting fate)
Do the RAC offer this service ? How do you go about getting it ?
I have full green flag cover under my bank account, would this fall under the take to nearest dealer to fix ?
spikeyboy101 wrote:Wise advise from others on here. Hope you get it sorted.
Not sure if the RAC Do but with the AA they will with there relay service ..
Unit 20
0151 3366888
0151 3366888
- TonyHayers
- 5th Gear
Yeah, you need the "Recovery" option with RAC it looks like: "We'll take you, up to 7 passengers and your car to your chosen destination anywhere in mainland UK."spikeyboy101 wrote:Wise advise from others on here. Hope you get it sorted.
^ GONE
^ GONE
Users browsing this forum: Google [Bot] and 325 guests
