first impressions after test drive
Re: first impressions after test drive
The mini system sounds the best. No button and always on. You just press the brake normally and it just keeps the brakes on for a second - enough time to sort out clutch and accelerator balance.
Works well enough in conjunction with the handbrake.
The Hill Hold thing has NO button. The "A" button next to the handbrake button is Auto Brake, and has nothing to do with Hill Hold. Hill Hold engage the brake when you go uphill. It activates when you step on the brake pedal and come to a complete stop. If you do that then the car wont move unless you step on the accelerator. It will also disengage after 2 seconds if you are not stepping on the brake pedal. The auto brake is another features that is like the hill hold but works regardless of the situation and it is very annoying. Most people do not use it.
Ah right - perfect.
I was surprised to see it was a button
In that case for 65 quid it's a no brained as it is quite handy.
Does the rs4 b8 box creep forward like a conventional auto?
News to me! I always activate the A button thinking it was hill hold. Going to have a play tonight.
2011: 2.0T FL Octavia VRS
2010: 1.8T Octavia VRS
Indeed it does, though not sure what it's like on a hill without hill hold. My R32 would roll back unless you had used the handbrake and then taken your foot off the brake.adsgreen wrote:Does the rs4 b8 box creep forward like a conventional auto?
The"A" button is for the stop start system nothing to do with hill hold.Nickyboy wrote:News to me! I always activate the A button thinking it was hill hold. Going to have a play tonight.
This one matelongdog wrote:The"A" button is for the stop start system nothing to do with hill hold.Nickyboy wrote:News to me! I always activate the A button thinking it was hill hold. Going to have a play tonight.
NICKYBOY is correct the A button is for hill hold assist ive got it on mine {2010} S4 model and don't have start stop.Nickyboy wrote:This one matelongdog wrote:The"A" button is for the stop start system nothing to do with hill hold.Nickyboy wrote:News to me! I always activate the A button thinking it was hill hold. Going to have a play tonight.
You clearly don't know what your on about,i suggest you look at the cars handbook.vjma wrote:The Hill Hold thing has NO button. The "A" button next to the handbrake button is Auto Brake, and has nothing to do with Hill Hold. Hill Hold engage the brake when you go uphill. It activates when you step on the brake pedal and come to a complete stop. If you do that then the car wont move unless you step on the accelerator. It will also disengage after 2 seconds if you are not stepping on the brake pedal. The auto brake is another features that is like the hill hold but works regardless of the situation and it is very annoying. Most people do not use it.
The statement 'If you do that the car move won't move unless you step on the accelerator' is incorrect.
In the FL cars there is another 'A' button which is start stop. This one is located nearer to the drink holders.
Yes they have changed the button layout on the fl heres the pre fl layout with the hill hold A button.
NICKYBOY when you get time photograph the start stop button please.
Two secs.
Users browsing this forum: Majestic-12 [Bot] and 39 guests
