C5 RS 6 LED Kit
Re: C5 RS 6 LED Kit
Got mine Trups, cheers for getting them out so quick.
Re: C5 RS 6 LED Kit
Based on Amar's recommendation, I will have some off you, Trups. Irritating timing because I was in Wollaston last week. Ho hum.
Re: C5 RS 6 LED Kit
Not often you hear those 2 words in a same sentence that isn't "the French wouldn't know what quality was if it came up and kicked them in the baguette and onions".Mr Footlong wrote: quality French
- Mr Footlong
Re: C5 RS 6 LED Kit
Shopp, if you still have my postage details get Trups to post them to me and i will bundle them in with those pads and send them all over to you...
Current:
Gone:
Gone:
Re: C5 RS 6 LED Kit
You two swap pads more times then DK swaps cars, I'm starting to think 'pads' is a code name for something else.
Re: C5 RS 6 LED Kit
Panty pads.
Re: C5 RS 6 LED Kit
Michelin.Shoppinit wrote:Not often you hear those 2 words in a same sentence that isn't "the French wouldn't know what quality was if it came up and kicked them in the baguette and onions".Mr Footlong wrote: quality French
To be honest, I'm actually quite looking forward to my DS3, the DS range is actually quite a good vs Ford/Vauxhall/Renault etc... They are what they are really, as long as you don't compare them to Audi/BMW. The main thing is, I am really enjoying working for the company, and am 10x happier here then I were at my old place, and I didn't mind my old place.
Re: C5 RS 6 LED Kit
Just fitted mine today, thanks for quick shipping Trumps, the only niggle i had was the door lights i had to solder them in, as they were like the Christmas lights with the single wires on the end of which were a bit hit and miss when connecting, so i just clipped them off and soldered the wires on direct, not a problem really, now the car lights up like a frigging Christmas tree now, looks great.
Bobby
Bobby
RS6 Saloon 04- Non Res Milltek- Forge dump valves- Led Rear Lights- Ally steering paddles- 20" Rotors- RNS-E- I.G Air Fiters,
Re: C5 RS 6 LED Kit
Anyone having issues with the map lights? If I turn them on using the push switch they don't want to light up. They come on fine when the doors are opened.
I also had an incorrect bulb but that's no big problem.
Re: C5 RS 6 LED Kit
Same hear same symptom also on the door lights i have 2 x red ones on the bottom of the driver side on the passanger side i have clear ones on the bottom, might try and sourse 2 more clear ones to make it the same around, but i do like them,
Bobby
Bobby
Re: C5 RS 6 LED Kit
Bobby,
so you have 2 red lenses on the driver and 2 clear in the passanger?
do they not need swapping so they are even?
Trups
Trups
Re: C5 RS 6 LED Kit
Hi Trumps, i have 6 red and 2 white so cannot swap any chance you sending out 2 white ones so i can keep it equal? while your at it can you explain the issue with the map lights If I turn them on using the push switch they don't want to Light up. They come on fine when the doors are opened.
Thanks mate
Bobby
Thanks mate
Bobby
Re: C5 RS 6 LED Kit
did i send you 6 red bulbs and 2 white? or do you have 6 red housings and 2 white?
the low curent is whats causing that, i will try and work out how to resolve this, Mr footlong did write about this when he 1st did it to his a earlier this year with no resolution so far.
i think it would just need a resistor but i can try it out if i get someone over to fit them.
TRUPS
TRUPS
Re: C5 RS 6 LED Kit
Hi Trumps, no problem mate, you did send 6 x red and 2 white ones,
Bobby
Bobby
Re: C5 RS 6 LED Kit
Hi rob,
Can you send 2 reds back and il swap them for 2 whites? i will also cover the cost of postage for you to send back.
Users browsing this forum: Google Adsense [Bot] and 322 guests
