225/40/18 Tyre Pressures
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Dippy
Post by Dippy » Wed Sep 15, 2004 8:58 am
Now that I've got my new wheels, I need to confirm the tyre pressures I should use. The fitter set them at 32 all round.
Does anyone know what pressures I should set? Is there an 'official' figure?
2001 Silver S4 Avant
DavidT
Post by DavidT » Wed Sep 15, 2004 9:59 am
I've got 235/40/17's on standard wheels and I run 38 all round.
I tried 34 and they just felt loose - too much give in the sidewalls I guess. 40 is too bouncy.
You will notice a harder ride I expect because of the lower profile, I did. It always amazes me when I swap to 45 tyres (track wheels) just how much of a difference there is.
Dippy
Post by Dippy » Wed Sep 15, 2004 1:11 pm
Thanks David. Although I've not had much time to judge, I haven't noticed the ride being much harder at all.
However the car does feel a little bit 'loose' when cornering hard, so maybe I should use a higher pressure and that will make the ride harder.
Does anyone else have a comment?
Nige_RS4
Post by Nige_RS4 » Wed Sep 15, 2004 1:31 pm
Dippy, here's a selection of answers when I asked the same question last year ...
http://www.rs246.com/index.php?name=PNp ... highlight=
I currently run 36 on the front and 34 on the rear - I tried 38 all round, but my teeth didn't like it on all but the smoothest of roads.
Nige.
Dippy
Post by Dippy » Thu Sep 16, 2004 12:16 pm
Thanks Nige.
Dippy
Post by Dippy » Thu Sep 16, 2004 12:18 pm
Thanks Nige.
DavidT
Post by DavidT » Thu Sep 16, 2004 12:29 pm
Lowering the rears way down to about 25 does make for some pretty exciting oversteer action. Not for the public roads though.
eric_mok
Post by eric_mok » Thu Sep 16, 2004 2:57 pm
Correct me if i'm wrong. I thot the rear needs to run higher pressure to increase oversteer??
DavidT
Post by DavidT » Thu Sep 16, 2004 3:17 pm
eric_mok wrote:Correct me if i'm wrong. I thot the rear needs to run higher pressure to increase oversteer??
You may well be right, but I have experience of it the other way around too.
