Check your pipes
RIV
Check your pipes
Post by RIV » Mon Dec 03, 2012 10:13 pm
My oil breather pipes are well rusty and are being replaced at the mo, along with a new oil cooler my cars done 50k now and I would say there is going to be a lot more cars suffering the same fate, so check your pipes
Noyjatat
Re: Check your pipes
Post by Noyjatat » Mon Dec 03, 2012 10:48 pm
To got any pics buddy?
RIV
Post by RIV » Mon Dec 03, 2012 10:51 pm
got any pics buddy?
It's still in the work shop, will try and get my mechanic to take some
RobM
Post by RobM » Mon Dec 03, 2012 11:17 pm
Breather pipes?
Thought it was the oil cooler pipework suffering terminal rust around the crimp sleeves that hold the end fittings on. Mine were done 6k miles ago at 45k. Cooler and feed/return pipes replaced by Audi for previous owner.
Worth checking regularly though. If one let go properly during a 'spirited' drive you'd have a very good chance of lunching the engine before you cotton on to the problem
Cheers, :beerchug:
Rob
'06 RS4(B7)Avant. Phantom black Black optics Privacy glass SS+ Buckets Roundy-roundy steering wheel K&N. Black is never gonna fade!
Also red '94 2.8E Coupe quattro.
1.9TDi Avant. Bl&&dy good workhorse.
Bessie the Tractor. International BD414, oh yes!
Ducati TTF2, Spondon Ducati F1 & random other bikes
MartayMcFly
Post by MartayMcFly » Mon Dec 03, 2012 11:30 pm
My car came with receipts for it having been done in summer... pretty costly job too.
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2015 8V RS3 Stage 3 - sold
2017 Alfa Giulia Quadrifoglio
ROY
Post by ROY » Mon Dec 03, 2012 11:34 pm
Any quick way to check them without taking the bumper off ????
Gone but not forgotten boohoo !!!
RS4 Sprint Blue Avant on Dyno after Carbon Clean http://youtu.be/7lsBbmmaDQc
amanda1
Post by amanda1 » Mon Dec 03, 2012 11:37 pm
First sign of oil cooler pipe failure when driving is that your dash will light up like a christmas tree if it does so, pull over asap and switch off.
950 nm torque!
RIV
Post by RIV » Mon Dec 03, 2012 11:39 pm
Yeh sorry oil cooler pipes, you can see them without taking the bumper off
Targa27
Post by Targa27 » Tue Dec 04, 2012 11:19 am
Im working in Belgium at the moment, came out of a shopping centre to see someone pointing at a large pool of oil under my car. Got it back and stripped myself to find the oil cooler pipes destroyed with rust.
Personally I cant understand how this is acceptable.... its a disgrace for a car like this.
Of corse as experienced by many others on here, its almost impossible to remove the hoses from the cooler without destroying the threads. Hence a 4 day wait and 800eur bill from local Audi garage here!
When i find out how to post pics i will.... :roll:
Iain_S4
Post by Iain_S4 » Tue Dec 04, 2012 2:19 pm
Mine failed within 2 years. I think I was the first to report the issue back in 2009. At the time it was just a small oil leak, spotting drops where the car had been parked
http://forum.rs246.com/viewtopic.php?f= ... oil+cooler
I really must pull my finger out to inspect and grease up the lines again. What are peoples views on wrapping them with denso tape? I've not looked so not sure how much needs wrapped or just the fittings at the end.
j1sgo
Post by j1sgo » Tue Dec 04, 2012 4:08 pm
Mine has done circa 50k and the oil cooler pipes were very rusty, i wire brushed and coated them with 3 generous brush coats of hammerite, think i have got away with it :sekret:
I may inspect and greese them before heavy winter too as that was a few monthes ago.
+1 for the bad quality steel/finish by Audi :audibash:
RIV
Post by RIV » Tue Dec 04, 2012 4:52 pm
Just got my car back, not a cheap job!! Like what has been said it is very very difficult to cut the pipes free from the oil cooler without ruining the threads, bad bad design from Audi, one I would check out if you have not looked before, been a very busy day forget to get mechanic to take photos
Rigsby1208
Post by Rigsby1208 » Tue Dec 04, 2012 6:28 pm
OK so any advice or links to how to check our pipes??
KernowPete
Post by KernowPete » Tue Dec 04, 2012 6:59 pm
Rigsby1208 wrote:OK so any advice or links to how to check our pipes??
+1, advice please. Mine's done 56k now so would appear to be in the danger zone, although no signs of leaks etc at the moment.
2007 B7 RS4 Phantom Black Saloon - stock
Previous: Lightly modded Mondeo ST220 (great car), nothing else worth mentioning!
RIV
Post by RIV » Tue Dec 04, 2012 9:04 pm
When looking at the pipes on my car it was up in the air on a ramp with the cover under the engine removed, you will be able to see the pipes going to the oil cooler which is behind the front bumper, to remove the oil cooler the bumper has to be removed, sorry not the best explanation I know :biggrin2:
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 74 guests
