Refuses to start in the cold!!!!!
RS4ABM
Post by RS4ABM » Tue Dec 04, 2012 12:19 pm
So, we have had a few cold mornings now and it seems to be causing the RS some issues. (add it to the list) So I get in, stick the key in, fuel pump fires up, clutch down and push the button...... click!! nothing. I then try again and after a few attempts away she goes.
Any ideas??
Adam
2007 RS4 B7 Mugello Blue - non res Miltek system - KW V3 coilovers - SMF - CAF - Custom oil cooler setup and LEDs galore
2009 FN2 Civic Type R Championship white
1990 Mini cooper (ish, its in a few bits)
Re: Refuses to start in the cold!!!!!
Post by Ian_C » Tue Dec 04, 2012 12:38 pm
Starter motor relay on the V8 is a known weak spot. Problem is I think its built into the starter motor which is a pig to access
adsgreen
Post by adsgreen » Tue Dec 04, 2012 1:43 pm
Curious - was it dark and the headlights on?
RS4ABM
Post by RS4ABM » Tue Dec 04, 2012 2:00 pm
Ian_C wrote:Starter motor relay on the V8 is a known weak spot. Problem is I think its built into the starter motor which is a pig to access
Ahh ok, this makes sense. Is it a big job on these?
RS4ABM
Post by RS4ABM » Tue Dec 04, 2012 2:01 pm
adsgreen wrote:Curious - was it dark and the headlights on?
No neither, its usually the first start in the morning once its been sitting all night
MaLicE
Post by MaLicE » Tue Dec 04, 2012 4:44 pm
My s4 is the same, it's the starter sticking, need to replace with a new one, its a pain to do as well :( I'm waiting on some warmer weather before I do it, or I can find a garage I can use and will do it myself to save on the labour costs.
RIV
Post by RIV » Tue Dec 04, 2012 4:54 pm
Had the same problem with mine, it turned out to be a relay cheap fix I'm sure
RS4ABM
Post by RS4ABM » Tue Dec 04, 2012 5:21 pm
I may change the relay first then before investigating the starter motor, any ideas where the starter relay is?
If not ill RTFM!!
MaLicE
Post by MaLicE » Tue Dec 04, 2012 6:21 pm
If you manage to fix it with that please let me know lol! But I'm sure when mine eventually starts I can hear a noise from the starter solenoid retracting a couple seconds after I have let go of the key...
nihc
Post by nihc » Tue Dec 04, 2012 10:25 pm
Hi,
Get this:
http://www.ebay.co.uk/itm/Audi-TT-A2-A3 ... 337dc5a686
It's the elsawin repair manual - the same that the Audi dealers use. I've got the same and it's brilliant.
Or, like I used to do, you can go to the audi erwin site and get the same information for a charge:
http://erwin.audi.com
Both show all of the workshop information you'll ever need.
Regards, Chris.
andymc
Post by andymc » Tue Dec 04, 2012 11:33 pm
I have noticed in this colder weather (and after returning from a 10 day vacation) that when I depress the start button - instead of the instant starter motor - there is now a delay of half to 1 second before the starter kicks in. I had assumed it was battery power related. After a few long drives it seems better - but I still get a tiny delay in the mornings when its still below zero outside.
RS4ABM
Post by RS4ABM » Wed Dec 05, 2012 10:23 am
nihc wrote:Hi,
Get this:
Regards, Chris.
Just made the purchase, looks like this could be very helpful.
Cheers :thumbs:
alex020869
Post by alex020869 » Wed Dec 05, 2012 10:36 am
Wish it would work on a Mac!!!!
Alex
RS4 B7 Mugello Blue Saloon
adsgreen
Post by adsgreen » Wed Dec 05, 2012 11:34 am
Don't forget batteries are at something like 40% operating capacity even when fully charged in these temps.
Starting that v8 must be a fair ole job.
RS4ABM
Post by RS4ABM » Wed Dec 05, 2012 5:50 pm
adsgreen wrote:Don't forget batteries are at something like 40% operating capacity even when fully charged in these temps.
I wish it was the battery, but she doesn't even turn just sits there waiting.......... and go, after about 5 pushes of the button!
Users browsing this forum: Google [Bot] and 100 guests
