Door Handle Problems
ChrisRS6
Post by ChrisRS6 » Thu Nov 15, 2012 1:25 pm
I've done some searches on here, and found threads about the micro-switches failing in door handles, which appears to confuse the car into thinking that the door isn't shut / open when it actually is.
I think I have a slightly different problem though.
On a few recent occasions, I have tried the driver's door handle and nothing happens. Yes - I've unlocked the car first with the key-fob, but when I pull the handle - nothing. The door doesn't open.
Sometimes it takes another 10 or so pulls for the mechanism to open the catch.
Sometimes a lock and unlock on the keyfob and then the handle works first time.
Changing from a normal (gentle) pull on the handle to a more robust tug on the handle also seems to make no difference.
It feels to me like a mechanical link between handle and latch, but am I wrong? Is this an electric link which is going squiffy?
Any ideas? So far I've tried a well aimed squirt or two of WD40 into the latch mechanism when the door is open but the problem is still intermittant.
Once open, the door closes fine.
*SOLD* - currently looking for a replacement
03 Missano Red Avant
Silver Leather, H&Rs, Dension iPod Connection kit
85k miles
Daveperc
Re: Door Handle Problems
Post by Daveperc » Thu Nov 15, 2012 2:08 pm
Not had precisely your symptoms, but I have had to have a door lock replaced on both of mine - had one done last night! New lock is £123 and about an hour to fit. In both cases it was the internal latch mechanism that was basically worn out.
Dave
wainwright
Post by wainwright » Thu Nov 15, 2012 6:55 pm
hi, I've had the same problem, it's a plastic connecter on the push rod mechanism off the handle,
good news it only cost about a quid, bad news it's a sod to fit.
Post by chunky79 » Thu Nov 15, 2012 7:35 pm
wainwright wrote:hi, I've had the same problem, it's a plastic connecter on the push rod mechanism off the handle,
FON, welcome to the mad house!
Keaney
Post by Keaney » Thu Nov 15, 2012 9:06 pm
I have a similar problem on the driver side, I find if I push the door I hear a click and then try again to open it which generally works
A7 3.0T - Pretty Std at the moment... in warranty
VW Caddy 2k 1.9 TDI - Std
Has beens:
C5 RS6 Avant - Wagbo'd, PSS9, MiIltek Res, MRC Stage 2, ACE Torque Converter, 551ps 815nm | 00 B6 A4 2.5TDI | 01 Nissan R34 GTR V-Spec (UK) | 93 Toyota MR2 GT | 95 Mitsubishi FTO | BMW 318is | Vauxhall Corsa 1.4 16v SRI | Vauxhall Nova 1.3SR Chavtastic
swannny
Post by swannny » Thu Nov 15, 2012 9:58 pm
double FON!
swannny
Post by swannny » Thu Nov 15, 2012 10:00 pm
my drivers door has just started doing this, and my allroad done it too,
i tried many thins, but the only thing that worked for me is what dave said, new lock. its one of the cheaper fixes to do!
ChrisRS6
Post by ChrisRS6 » Fri Nov 16, 2012 1:28 pm
Cheers for the responses all.
It's MOT day today, so fingers crossed that the problem doesn't occur today!
Think I'll just monitor the issue and if it starts becoming more regular, sounds like a lock replacement will be the way forward, although I will firstly investigate the £1.00 plastic connector on the push-rod that Wainwright mentions.
It'll hopefully wait until a warm day before I start fumbling around with tiny fixings for the door trim. Trying to do this on the driveway in mid December with numb fingers doesn't sound fun.
85k miles
Post by bam_bam » Fri Nov 16, 2012 1:58 pm
double FON!
FON FON FON.
RS6JJL
Post by RS6JJL » Wed Jan 09, 2013 9:28 pm
Any updates on this mine is doing it on the drivers door and i can't actually get in now
KV53 YML - RS6 Avant - Stolen Hampshire
RS 51X CS - RS6 Avant - Sold
bilko1
Post by bilko1 » Wed Jan 09, 2013 10:44 pm
RS6JJL wrote:Any updates on this mine is doing it on the drivers door and i can't actually get in now
Get Bam round he's a master at getting in the RS6. :jump:
RS6JJL
Post by RS6JJL » Wed Jan 09, 2013 10:51 pm
well the door is locking and dead locking fine, its opening fine from the inside handle
its just from the door handle where its not doing much at all on the outside
takes about 10 attempts to open it and it will open from the handle something is not lining up somewhere causing this problem
why can't audi make a proper car :audibash:
Post by chunky79 » Thu Jan 10, 2013 7:59 am
They did make a proper car, but things wear! You do know your car is at least 9 years old don't you. Sounds like you need a new catch or linkage, strip the door and have a look.
Post by Shoppinit » Thu Jan 10, 2013 8:31 am
What Chunky said. With cream on top.
ChrisRS6
Post by ChrisRS6 » Thu Jan 10, 2013 1:23 pm
No update from here either.
I've done nothing about looking into this problem. I'm plucking up courage to strip the interior door trim off (but not sure where to start with this) to have a poke around to see if I can spot something obvious which is worn.
95% of the time it works fine, but once or twice I've had to ask the passenger to get in first, lean across and open the driver's door from the inside!
85k miles
Users browsing this forum: Steve2003rs6 and 852 guests
