G28 speed sensor
chrisn6
G28 speed sensor
Post by chrisn6 » Tue Nov 13, 2012 5:01 pm
Hi guys,
It looks like I've been supplied the wrong sensor. Furthermore, my mechanic is struggling to get to the sensor, but from what he can see, the cable is part of the sensor and looks bigger than the one I've been supplied which requires the cable plugs into it.
Has anyone here replaced one? Any tips?
Thanks in advance,
~Chris
chrisn6
Re: G28 speed sensor
Post by chrisn6 » Tue Nov 13, 2012 5:04 pm
I'm also slightly confused by some people referring to it as a crank position sensor. Some Audis appear to have both a crank sensor G4 and an engine speed sensor G28. Does the RS6 make do with just the one or is there also a G4 sensor which is maybe the one my mechanic has found? Anyone have a schematic that shows the layout?
Thanks again,
~C
Nobby
Post by Nobby » Tue Nov 13, 2012 5:49 pm
Sorry if I've missed something, but what it the problem you have?
RPM not working or speedo. RPM is normally a crank position sensor, speedo is normally a gearbox/final drive sensor. I'd be surprised if the RS6 used a cable operated sensor as they aren't particularly reliable. More likely a hall effect sensor.
Have you looked on elsaweb/vagcat and had the car scanned for errors?
Daytona RS6 Avant
Post by bam_bam » Tue Nov 13, 2012 6:04 pm
chrisn6
Post by chrisn6 » Tue Nov 13, 2012 6:04 pm
Hi Nobby,
Sorry, you obviously missed my other thread "Worrying Experience" where Shop correctly diagnosed a faulty engine speed/crank sensor. My Vagcom verified this. I sourced a sensor which is not the right one, and it looks like it's a main dealer only part after further searches. Looks like a job for Virdee after all...
I just wanted to be 100% sure that there is only one crank/speed sensor on the beast, as many other Audis have two.
~C
Stoo.
G28 speed sensor
Post by Stoo. » Thu Nov 15, 2012 1:22 am
G28 is the crank sensor
G40 is cam sensor
It Will have both.
EDITED TO CORRECT MY TIRED (tard) STATE!!
Nobby
Post by Nobby » Thu Nov 15, 2012 7:47 am
I think that's wrong Stoo.
G28 is engine speed sensor
G40 is cam sensor 1, G163 is cam sensor 2.
Cam sensors are a little bigger and have 2 bolts that attach them.
Daytona RS6 Avant
chrisn6
Post by chrisn6 » Thu Nov 15, 2012 8:32 am
Nobby is correct according to the system layout diagram I found in a C5 study guide. Should be receiving the sensor from Audi today. Apparently it takes between 2 and 3 hours to fit.
~C
Stoo.
G28 speed sensor
Post by Stoo. » Thu Nov 15, 2012 9:29 am
Whoops.
I was Half asleep at 0122!!
I was only looking at them yesterday too!!!
brassy1975
Post by brassy1975 » Wed Dec 31, 2014 6:45 pm
IV GOT AN RS6 C5 AND ITS REVING THEN JUMPING INTO GEAR BUT NOT ALL THE TIME ONLY ON AND OFF BEEN TOLD ITS THE CRANK SHAFT SENSOR
Users browsing this forum: Majestic-12 [Bot] and 73 guests
