Tyre Pressure warning errors
adriangwatson
Post by adriangwatson » Sun Oct 14, 2012 8:01 pm
Hi guys. I've tried researching this question on here but still a bit confused....
I have a permanent Tyre Pressure red light warning come up on the DIS. I've checked the tyre pressures a couple of times now and the tyre pressures are fine.
Does this mean that the batteries in the tyre sensors are probably flat? I have an 06 model which I have only had for a year, and am not sure whether they have ever been replaced. Is there any way I can easily check?
Does it make most sense to just take it to an authorised dealer or am I best off just buying some new sensors online and getting a tyre Shop to fit them?
Thanks for any advice
D8vil
Re: Tyre Pressure warning errors
Post by D8vil » Sun Oct 14, 2012 9:09 pm
Have you reset the pressures in the computer menu ?
adsgreen
Post by adsgreen » Sun Oct 14, 2012 9:18 pm
Vag Com should tell you the error code but yes, likely the batteries are flat.
adriangwatson
Post by adriangwatson » Sun Oct 14, 2012 10:19 pm
D8vil wrote:Have you reset the pressures in the computer menu ?
Hi, I'm not sure if I can because the red light seems to block out the functionality on the DIS.
GLOL
Post by GLOL » Mon Oct 15, 2012 7:25 am
You can - I had this at the weekend. Just follow the instructions in the handbook to reset the pressures to the current value. Fixed my red warning sign...
alex020869
Post by alex020869 » Mon Oct 15, 2012 8:25 am
Anyone know if the sensors are expensive to replace?
Alex
RS4 B7 Mugello Blue Saloon
adsgreen
Post by adsgreen » Mon Oct 15, 2012 9:17 am
alex020869 wrote:Anyone know if the sensors are expensive to replace?
Alex
80-100 quid each plus fitting and possibly valves.
alex020869
Post by alex020869 » Mon Oct 15, 2012 9:41 am
Alex
Can the batteries be replaced or are they sealed units?
Alex
PetrolDave
Post by PetrolDave » Mon Oct 15, 2012 5:26 pm
alex020869 wrote:Can the batteries be replaced or are they sealed units?
They're sealed units.
adriangwatson
Post by adriangwatson » Mon Oct 15, 2012 5:34 pm
GLOL wrote:You can - I had this at the weekend. Just follow the instructions in the handbook to reset the pressures to the current value. Fixed my red warning sign...
Thanks, will give it a go. Fingers crossed. Having to spend £400+ on tire pressure sensors seems pretty punchy.....
PetrolDave
Post by PetrolDave » Mon Oct 15, 2012 5:41 pm
adriangwatson wrote:Having to spend £400+ on tire pressure sensors seems pretty punchy.....
VCDS can tell you which of the sensors have dead batteries.
spikeyboy101
Post by spikeyboy101 » Mon Oct 15, 2012 5:54 pm
i keep getting a yellow flat tyre symbol with a line through it - comes on for a while and goes off.
Tyres are always ok on pressures - diagnostic just gives a general error and doesnt point the finger at anything particular - any ideas ?
Post by chunky79 » Mon Oct 15, 2012 5:56 pm
Think yours is turned off then.
PetrolDave
Post by PetrolDave » Mon Oct 15, 2012 6:08 pm
spikeyboy101 wrote:i keep getting a yellow flat tyre symbol with a line through it - comes on for a while and goes off.
Try looking at the measuring blocks, that's where the details of pressure, temperature and battery voltage can be seen for each tyre.
adriangwatson
Post by adriangwatson » Sat Oct 20, 2012 5:26 pm
Thanks for the advice - I reset the values and it seems to have done the trick.
Users browsing this forum: Google Adsense [Bot] and 45 guests
