Oil cooler
Gazzaton
Oil cooler
Post by Gazzaton » Wed Oct 10, 2012 12:13 pm
Driving home last night and oil pressure warning light came on, was driving over the Kingston bridge (Glasgow) so wasn't able to pull over as quickly as would have liked. Into the garage this morning and they confirmed what I thought had happened, oil cooler and pipes burst due to corrosion. They're going to put a bridge pipe in first so, they can fill it with oil and make sure there's no damage to the engine (fingers crossed).
My question is, is there replacement pipes and connections that you can get that stop the corrosion ie. the same metal as the oil cooler?
'57 Avant, Black with black optics pack, milltek resonated and valved, 200 cell high-flow cats, de-vaned port n polished manifold, stage 2 remap, Revolution carbon-fibre induction kit
GlenRS
Re: Oil cooler
Post by GlenRS » Thu Oct 11, 2012 7:39 am
I just replaced my lower oil pipe ( cooler and upper hose were fine) after I fitted the new hose I sprayed it all over with white grease on the exposed end where it corroded before.
mc72
Re: Oil cooler
Post by mc72 » Thu Oct 11, 2012 10:23 am
I posted about replacing the pipes a few weeks back and have now found that the cooler connections are corroded away so it'll need changed anyway. An expensive job all in.
CRSRS
Re: Oil cooler
Post by CRSRS » Fri Oct 12, 2012 4:58 pm
Mine was in Perth Audi a couple of months ago and the tech said there was evidence of corrosion and should do sooner rather than later. Where did you take it in Glasgow? Are they replacing cooler as well as pipes?
2007 RS4 Avus avant - now gone
2013 RS3 black - bye bye
2013 B8 RS4 - Sepang, Ceramics, Buckets, Carbon pack, Sports pack, ACC, B&O, privacy. - now gone
2017 C7 PE - Panther, Ceramics, Carbon pack, BO upgrade.
Users browsing this forum: No registered users and 109 guests
