Tyre time...!
Re: Tyre time...!
Looking at the configurator you can get the 255/225 front / rear combo on both 8J and 8.5J rims. Would it be that bad if you had 255 front and rear?
Re: Tyre time...!
255 at the front and rear won't reach the effect we're talking about.P_G wrote:Looking at the configurator you can get the 255/225 front / rear combo on both 8J and 8.5J rims. Would it be that bad if you had 255 front and rear?
Wider tire at the front eliminates understeer..
Leave the rear ones 225.
- Dave_Hedgehog
- 5th Gear
Re: Tyre time...!
the description gives that impression but if you mouse over the two rows of wheels 255s are all 8.5J
im glad i got it thou
The Hedgehog, creator of RS4.org, back in of the RS fold yet again, third time lucky
- Dave_Hedgehog
- 5th Gear
Re: Tyre time...!
JonG wrote:Thats a big difference in rolling diameter front to rearnicholas wrote:I would go for:
255/35/19 front
225/35/19 rear
i hadnt thought of this
this is my 255 8.5J v 235 8J (as a potential winter tyre)
207.69 v 203.29
not to bad, i could live with that for a winter wheel
- Dave_Hedgehog
- 5th Gear
Re: Tyre time...!
comparing 255 front to 225 rear and stock 235 front to 225 rear
Re: Tyre time...!
I don't qute follow that logic?nicholas wrote:255 at the front and rear want reach the effect we're talking about.P_G wrote:Looking at the configurator you can get the 255/225 front / rear combo on both 8J and 8.5J rims. Would it be that bad if you had 255 front and rear?
255 tyres were put on the front because as it was seen that the grip offered over 235 was signnificant enough to warrant it. Much like us RS4 owners will put on 275/30 rather than 255/35 and have seen better turn in grip, part of the understeeer elminaton solution. RS3's are Haldex driven so predominantly front wheel drve so what grip the rears have should not have an adverse effect on the fronts i.e. put a wider tyre on the rear = more grip and the back = does not induce understeer. As for rollng radius, the speedo measures off the front axle IIRC and if the difference is <5% it shouldn't damage the Haldex.
I just find it a bit of an odd set up?
- Dave_Hedgehog
- 5th Gear
Tyre time...!
It's also about the balance between front and rear axel not just individual axel grip. increasing the rear grip will induce more oversteer on the limitP_G wrote:I don't qute follow that logic?nicholas wrote:255 at the front and rear want reach the effect we're talking about.P_G wrote:Looking at the configurator you can get the 255/225 front / rear combo on both 8J and 8.5J rims. Would it be that bad if you had 255 front and rear?
255 tyres were put on the front because as it was seen that the grip offered over 235 was signnificant enough to warrant it. Much like us RS4 owners will put on 275/30 rather than 255/35 and have seen better turn in grip, part of the understeeer elminaton solution. RS3's are Haldex driven so predominantly front wheel drve so what grip the rears have should not have an adverse effect on the fronts i.e. put a wder tyre on the rear = more grip and the back = does not induce understeer. As for rollng radius, the speedo measures off the front axle IIRC and if the difference is <5% it shhouldn't damage the Haldex.
Thats why some mid engined cars come with different sizes front and rear, I think our mr2 roadster had 16s on the front and 17s on the rear, I seem to remember the early NSX had a very odd tyre configuration
Re: Tyre time...!
I might be talking out of my
but does it have something to do with the width on the rears as well. I think 255's on the rears might cause a far bit of rubbing???
2019 RS3 4 door - Gone
Re: Tyre time...!
RSphantom wrote:I might be talking out of mybut does it have something to do with the width on the rears as well. I think 255's on the rears might cause a far bit of rubbing???
Re: Tyre time...!
Here's a question now...on a haldex quattro, should all 4 tyres be changed at the same time, or can "odd pairs" run without issue?
Have managed to source a reasonable price for the Michelin SuperSports but have about 3-4mm tread on the rears. Question is do I run a Michelin/Conti combination or all michelin?
- Dave_Hedgehog
- 5th Gear
Re: Tyre time...!
you can happily run different tread depth front to rear on quattro, because of the odd tyres there is a difference out of the boxGasman wrote:Here's a question now...on a haldex quattro, should all 4 tyres be changed at the same time, or can "odd pairs" run without issue?
if your basing on reviews im surprised your all not going for pirrelli p zeros which hammered everything in last months EVO tyre test
http://www.tyrereviews.co.uk/Article/20 ... e-Test.htm
- PetrolDave
Re: Tyre time...!
The big problem with P Zeros is that they are a very soft compound and wear out really fast (at least 50% quicker than any other tyre on a B7 RS4 in my experience) so they review well in a short tyre test but in the real world they go "off" very quickly. I will NEVER fit P Zeros to my RS4 despite them being what the factory fitted.Dave_Hedgehog wrote:if your basing on reviews im surprised your all not going for pirrelli p zeros which hammered everything in last months EVO tyre test
- 1st Gear
Re: Tyre time...!
do you all take 18" wheels for winter ? anyone been drivinf on snow with the 19" ?
- Dave_Hedgehog
- 5th Gear
Re: Tyre time...!
most people in the uk dont run winter wheels or tyresturbo roro wrote:do you all take 18" wheels for winter ? anyone been drivinf on snow with the 19" ?
Re: Tyre time...!
Thats too big a difference in rolling diameter IMHOnicholas wrote:Big, but for the RS3 it's for the better. There even is a wheel upgrade package with such configuration.JonG wrote:Thats a big difference in rolling diameter front to rearnicholas wrote:I would go for:
255/35/19 front
225/35/19 rear
I note that the Audi upgrade package has 255/30/19 tyres on the front and not 35 profiles, presumably to keep the rolling circumferences similar front to rear.
http://www.audi.co.uk/content/dam/audi/ ... rtback.pdf (page 24)
Audi RS3 in Daytona Grey, 7sp S-Tronic, Sept 2012.
Users browsing this forum: No registered users and 9 guests
