Transmission Program
Re: Transmission Program
Post by bam_bam » Fri Oct 05, 2012 3:47 pm
The MRC map won't do that, in tiptro, you'd have to depress the kickdown for the MRC GB map to be overriden.
Post by Shoppinit » Fri Oct 05, 2012 3:54 pm
^^That was as clear as syphilitic discharge.
Post by bam_bam » Fri Oct 05, 2012 5:09 pm
You'd know...
Post by Shoppinit » Fri Oct 05, 2012 5:21 pm
Might be clear for all I know. Doc? What's the answer?
Seriously, though, if I read you right you are saying that in tiptro the box *will* change down if you mash the pedal?
Post by bam_bam » Fri Oct 05, 2012 5:39 pm
Correct, you have to go past kickdown otherwise it'll hold a tall gear at WOT.
Post by Shoppinit » Fri Oct 05, 2012 5:40 pm
So basically doing exactly what the Viper one does. That would be no good to me.
Post by bam_bam » Fri Oct 05, 2012 5:47 pm
Shoppinit wrote:So basically doing exactly what the Viper one does. That would be no good to me.
Why, do you have a club foot? I've never had it kickdown unless I wanted it to. It's not a hair-trigger, you really have to engage the 2nd step for it to kick. I've logged it, I got WOT.
gingertoss
Post by gingertoss » Fri Oct 05, 2012 6:12 pm
My mrc map doesn't do that. 5th gear 30mph foot to the floor and it will stay in 5th
2003 RS6 Avant, non res Miltek, 3" catless dps, wagners, MRC air filters, 044 fuel pump, MRC custom remap, TCU remap, 566ps, 812nm, pss9 coilovers, hotchkis rollbars, Recaro CSs, 390mm front discs, hi-spec 4 pot rear calipers.
grizz
Post by grizz » Fri Oct 05, 2012 6:55 pm
Viper has a new map that will get rid of the kick down ...
Unit 20
0151 3366888
Mr V10
Post by Mr V10 » Fri Oct 05, 2012 6:57 pm
gingertoss wrote:My mrc map doesn't do that. 5th gear 30mph foot to the floor and it will stay in 5th
Ditto.
Post by Shoppinit » Fri Oct 05, 2012 7:00 pm
Bam, you are right. WOT and 100% accel position are achieved before kick-down. At least with engine off. I may log with engine on at some point just to make sure.
I still prefer no kick-down, though. I don't want to be thinking about exactly how much pressure I am applying with my club foot in the midst of the action.
gingertoss
Post by gingertoss » Fri Oct 05, 2012 7:03 pm
Re mrc and viper map, you must be able to ask for either or. Much prefer making the decisions myself rather than the tcu!
Post by bam_bam » Fri Oct 05, 2012 7:17 pm
Like I said, never has it kicked down in tiptro unless I wanted it too. Each to their own though.
Post by bam_bam » Fri Oct 05, 2012 9:42 pm
So I just tried it on the way home from the gym; 5th @ 30MPH then shoved my foot through the kick down, the gearbox promptly swapped from 5th to 1st (surprisingly smooth too), broke traction, spun up for a second, then snapped my neck as it gripped and ripped. It might be worth noting that I'm running a stage 2 TCU map but I don't think that matters.
Post by chunky79 » Sat Oct 06, 2012 7:07 am
Snapped your neck? You need to work on those muscles next session then.
I will test my car later when i take it in to work to do the arbs but i have a feeling it kicks down.
Users browsing this forum: No registered users and 60 guests
