Clutch pedal won't work
j-marksie
Post by j-marksie » Sat Sep 22, 2012 7:29 pm
Driving the rs today, went to change gear from 2nd to 3rd and it wouldn't go into 3rd. Took my foot off the pedal and the clutch pedal wouldn't return :( nursed it home (luckily I was nearly home). It will still drive just won't engage the clutch!? Anyone got any ideas? I imagine it will be expensive :( :(
Current B7 sprint blue saloon
Gone
Mk5 R32
Mk4 R32
Both great cars
Spaceman_RS4
Re: Clutch pedal won't work
Post by Spaceman_RS4 » Sat Sep 22, 2012 7:38 pm
Quick search gave me this
http://forum.rs246.com/viewtopic.php?f= ... ck#p497177
Poss clutch return pipe?
Ordered b9 S4 Avant ibis white
Panther black 8V RS3
Misano Red B7 RS4 Saloon
j-marksie
Post by j-marksie » Sat Sep 22, 2012 8:18 pm
That's talking about a heavy clutch, where as I think mine has been ok until today!? The pedal won't do anything? I take it that's it's not a clutch cable on these!? Seeing as you said return pipe?
Gone
Mk5 R32
Mk4 R32
Both great cars
Spaceman_RS4
Post by Spaceman_RS4 » Sat Sep 22, 2012 9:31 pm
There was a bit in there about the clutch sticking down and not getting gears something to do with a faulty return pipe. Dunno if it s was after they got hot have you been back out try once cool bud?
I'd search the return pipe bit.
j-marksie
Post by j-marksie » Sat Sep 22, 2012 10:14 pm
Ah right sorry didn't see that bit, I was that pissed off I've walked away from it tonight but will try it in then morning to see if it works. If so then could be that faulty return pipe! Fingers crossed, does Audi cover it as a recall?
Gone
Mk5 R32
Mk4 R32
Both great cars
Spaceman_RS4
Post by Spaceman_RS4 » Sat Sep 22, 2012 11:28 pm
No idea bud I'd never heard of it till I searched tonight, doubt it tho unless you have extended warranty you could try.
sonny
Post by sonny » Sun Sep 23, 2012 2:05 am
If the car wont go into gear (due to hydraulic clutch), make sure engine is turned off, select gear then start the engine, the car should be able to be driven in that gear, this should be able to get the car onto a low loader or elsewhere.
Sounds like the Clutch return pipe, will most likely need new clutch and possible flywheel...and most certainly a return pipe.
j-marksie
Post by j-marksie » Sun Sep 23, 2012 8:20 am
I take it that the return pipe comes from the thrust, through the bell housing to the slave cylinder? Therefore you would have to split it to get to it!? I've got a car lift, can you remove gearbox from underneath? Or is it engine out job? A lot of people talk about putting alternative clutches can anyone recommend any? Thanks for all your help by the way!
Gone
Mk5 R32
Mk4 R32
Both great cars
Spaceman_RS4
Post by Spaceman_RS4 » Sun Sep 23, 2012 9:50 am
A quick bit I read said the return pipe was a simple job so I'd doubt it's box out I'd research changing that first
j-marksie
Post by j-marksie » Sun Sep 23, 2012 10:15 am
Just tried it again this morning and still no different clutch pedal goes to the floor, really hard to push about an inche from the bottom of travel. And I have to return it by pulling it back.
Gone
Mk5 R32
Mk4 R32
Both great cars
Dal
Post by Dal » Sun Sep 23, 2012 10:37 am
j-marksie wrote:Just tried it again this morning and still no different clutch pedal goes to the floor, really hard to push about an inche from the bottom of travel. And I have to return it by pulling it back.
Any fluid on the ground ? Have you checked the reservoir to see if its full ?
B8 RS4 in the fastest colour :smile_smoking:
watts6087
Post by watts6087 » Sun Sep 23, 2012 2:11 pm
That is what happened to me on my rs. i needed and new clutch and dual mass fly wheel £1500 fitted.
j-marksie
Post by j-marksie » Sun Sep 23, 2012 4:08 pm
Still got clutch fluid in the resivoir
Gone
Mk5 R32
Mk4 R32
Both great cars
Users browsing this forum: Google Adsense [Bot], N9ATH and 118 guests
