Lower door blade
Brooner
Lower door blade
Post by Brooner » Sat Sep 08, 2012 12:28 pm
Anyone replaced the lower exterior door blade not sure if thats the correct term looks like only held on by 2 screws either end and some double sided sticky as it has come away just slightly at the pillar end and i could repair it myself but don't want to get too rough incase theres another screw hidden somewere
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
stu
Re: Lower door blade
Post by stu » Sat Sep 08, 2012 5:12 pm
Can't help, but I think Caldy is describing the same thing here eariler this week. Might be wrong:
http://forum.rs246.com/viewtopic.php?f=35&t=99005
yorkie
Post by yorkie » Sat Sep 08, 2012 6:37 pm
You undo the screws and it slides back away from the front of the door.
Unfortunately the reason it is coming away from the door is corrosion inside the trim which is not repairable.
There is no double sided tape, it clips onto studs welded onto the door skin.
Although the trim is plastic it has a metal strip through the middle which rusts and blows the plastic apart giving the appearance that it has come away from the door.
Had both my fronts done last year, about £65 each plus paint and not covered after 2 years by Audi but my local dealer made a contribution for goodwill.
androidmarrs
Post by androidmarrs » Sat Sep 08, 2012 6:53 pm
If they are anything like an old A4 I had there is only 2 screws. One at hinge side of the door and the other you see in your photo.
Remove the screws and pull the trim back it should move back about 10mm and then lift off. There is a row of white plastic clips fitted to the bottom of the door that lock into the groves in the moulding.
androidmarrs
Post by androidmarrs » Sat Sep 08, 2012 6:58 pm
ArthurPE
Post by ArthurPE » Sun Sep 09, 2012 3:14 am
Brooner
Post by Brooner » Sun Sep 09, 2012 1:43 pm
Thanks for the replys guys got it off today and yes it has corroded so i 'll get it replaced
tempo
Post by tempo » Sun Sep 09, 2012 2:02 pm
had mine done around may time and cost me £90 painted and fitted.
should of been £180 but audi paid 50%.
ArthurPE
Post by ArthurPE » Sun Sep 09, 2012 3:12 pm
ok, just pulled my passenger/front off, easy, 2 screws, slide rearward
a lot of dirt behind it, cleaned it all up with a brush, waxed the door
exactly as described, the blade mounting plate is delaminating at the top edge for about 12" from the rear of the door
I cleaned up the gap, dried with a heat gun, and squirted 2 part epoxy into it, then clamped the edge/lip with two 12" strips of wood/c-clamp, dries as we speak
make sure you have some adhesive remover/solvent on hand, when clamped it oozes out
it's the only door doing it so far, but I'll remove/clean all of them
I'll let you know how it turns out
edit: pulled the drivers side to clean it, started to delaminate ~6", not noticable yet, so did the same: cleaned, glued, clamped
ArthurPE
Post by ArthurPE » Sun Sep 09, 2012 4:43 pm
turned out perfect, perfectly flush and even gap
took less than 1 hour both sides (n/i drying time)
make sure you get ALL grit from behnd the plate, make sure it it dry and degreased, use a good epoxy, and clamp evenly with wood strips
we'll see how it holds up
Apowers
Post by Apowers » Thu Jan 10, 2013 5:57 pm
Has anyone got the part numbers to these as exactly what I'm after, cheers
Tile Diver
Post by Tile Diver » Thu Jan 10, 2013 6:12 pm
Yep, its the same as the S4 Arthur, I just removed my driver side one, ELSAWEB to the rescue again!!!
Black Optics / Ti Pack
SS Suspension +
Sunroof
H&R Hubcentric Spacers
Milltek Res / Valved Cat Back
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
If in doubt.. Power out!!
Tile Diver
Post by Tile Diver » Fri Jan 11, 2013 8:50 am
Apowers wrote:Has anyone got the part numbers to these as exactly what I'm after, cheers
Yeah, the part number would be good, I'm looking for the drivers door one, my ETKA parts catalogue seems to have stopped working!!
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
ArthurPE
Post by ArthurPE » Fri Jan 11, 2013 2:33 pm
my quick fix seems to be holding up well after 4 months
jobbys
Post by jobbys » Sun Nov 15, 2015 5:01 pm
Just in case anyone else need in future (being old Elsawin links don't work no more), lower moulding on driver's door is Part No: 8E0-853-960-7DL .
My original was coming apart and Audi dealer charged £220 to supply a painted replacement.
In this case replacing it genuinely was a 5 min job (well add 3 mins to wipe off residual crud left behind old one), with just the two screws to remove, slide to the left and it falls off.
Users browsing this forum: Majestic-12 [Bot] and 87 guests
