Possible options for iPod connection RNS-E
edge
Post by edge » Mon Aug 27, 2012 1:58 pm
Howdy,
So want to sort out the iPOD and the RNS-E finially.
How does DICE compare to the factory fit iPod set up?
Dension Gateway 100 Seems to be anther option?
Anyone have one fitted?
wolfgang
Re: Possible options for iPod connection RNS-E
Post by wolfgang » Mon Aug 27, 2012 4:23 pm
Alpine/Kufatec option is amongst the best out there.
2007 RS4 Avant in Mugello Blue + Milltek non-res valved, MRC air filter, MRC remap with silent-mode startup
PetrolDave
Post by PetrolDave » Mon Aug 27, 2012 5:21 pm
The best option is to swap your standard RNS-E to a 2010+ RNS-E, and swap the glovebox CD changer to AMI (with iPod lead) - if a good iPod connection is your priority.
C5ARK_RS4
Post by C5ARK_RS4 » Mon Aug 27, 2012 7:28 pm
I've got the Gateway and is the cheapest way of doing. It's perfectly fine for what I want. I did lose the cd multichanger but as I've got everything on iPod it wasnt a problem. I've read it's much better than oem as well.
chrisd31
Post by chrisd31 » Sat Sep 01, 2012 4:29 pm
how difficult is it to change to a 2010 RNS-E??
PetrolDave
Post by PetrolDave » Sat Sep 01, 2012 6:57 pm
chrisd31 wrote:how difficult is it to change to a 2010 RNS-E??
Find a 2010+ A3 or TT RNS-E as a donor; swap the faceplate between that and your existing RNS-E to create an A4 2010+ RNS-E; then sell the now A3 or TT pre-2010 RNS-E. The hardest part of the swap is that the screws are small and can be very tight so you must use the correct size screwdriver to avoid damaging the heads.
It's a direct plug'n'play to do the swap, just read the coding from you current RNS-E and code the new one exactly the same - until you swap the CD changer to the AMI when you change the last 2 digits of the coding, see http://wiki.ross-tech.com/wiki/index.ph ... 28RNS-E%29
(the AMI is coded as "digital radio").
The only thing you lose on the 2010+ RNS-E is the RS4 startup screen as it doesn't have it.
Users browsing this forum: Majestic-12 [Bot] and 118 guests
