changing default volume on RNSE... help
klauster
Post by klauster » Sun Aug 19, 2012 3:12 pm
Is there a way to change the volume of the RNSE when you first start up the car? Can it be done through vag.com? Anone know where its hidden?
TimDogg
Re: chnaging default volume... help
Post by TimDogg » Sun Aug 19, 2012 7:44 pm
I'll look into that, I'm also not sure my volume is increasing as the ambient noise increases, trying to figure out how to activate that too.
'56 ST220 (Sold)
'97 ST24 (Sold - loved lots)
Post by MikeFish » Mon Aug 20, 2012 11:25 pm
Yeah this is problem for me too as I use my processor to control the volume and have to set the RNS-E volume to just below clipping point but every time I turn the ignition off then on it decides to lower the lower and I have to find the max volume point again.
klauster
Post by klauster » Wed Aug 22, 2012 6:33 pm
no one got any advice on this?
PetrolDave
Re: changing default volume on RNSE... help
Post by PetrolDave » Wed Aug 22, 2012 7:05 pm
This question got asked a lot a few years ago, but no definite answer was ever found.
For some people, me included, setting the volume on the RNS-E "Radio TestMenu 3" Engineering Mode screen worked - but that didn't seem to work for everyone.
ROY
Post by ROY » Wed Aug 22, 2012 7:07 pm
TimDogg wrote:I'll look into that, I'm also not sure my volume is increasing as the ambient noise increases, trying to figure out how to activate that too.
This is annoying me too Tim
I've checked as much as I can but can't find no settings
Gone but not forgotten boohoo !!!
RS4 Sprint Blue Avant on Dyno after Carbon Clean http://youtu.be/7lsBbmmaDQc
Post by MikeFish » Wed Aug 22, 2012 10:49 pm
Is your suggestion to make the volume change with ambient speed or is it to change the turn on volume?
PetrolDave
Post by PetrolDave » Thu Aug 23, 2012 5:37 pm
MikeFish wrote:Dave
It's about the subject of this thread - changing the default volume.
Changing the volume vs. speed setting does nothing as the Bose AudioPilot system resets that anyway.
Post by MikeFish » Thu Aug 23, 2012 5:48 pm
I only asked because the second post also asked about the ambient noise issue and it was not clear from then on whether everyone was still talking about the original issue or not. Also your picture had the gala setting highlighted and I thought this was the name for the ambient noise setting.
PetrolDave
Post by PetrolDave » Thu Aug 23, 2012 6:51 pm
MikeFish wrote:Also your picture had the gala setting highlighted and I thought this was the name for the ambient noise setting.
That's a "stock" picture not one I took specifically for this thread.
"GALA" is a bit of a misnomer, because we have AudioPilot which isn't speed dependent volume changing - it's background noise dependent volume changing. There's a microphone in the interior light that measures interior noise, the Bose amp subtracts the "music" signal from that to get an estimate of the interior noise which it use to adjust not only the volume but also the frequency response of the Bose amp.
GALA based speed dependent volume changing did nothing when driving on rough roads, but AudioPilot increases the volume to compensate.
Post by MikeFish » Thu Aug 23, 2012 9:03 pm
Ok thanks for clearing that up. So (off topic I know) if I am not using the Bose amp there is no sound level change going on (which is exactly what I want)?
Now just need to stop the volume going down every time I restart the car.
PetrolDave
Post by PetrolDave » Sat Aug 25, 2012 11:49 am
MikeFish wrote:Ok thanks for clearing that up. So (off topic I know) if I am not using the Bose amp there is no sound level change going on (which is exactly what I want)?
There's no change going on in the amp (As you're not using it) but if your RNS-E is coded for an A4 or Bose sound characteristic (i.e 301xxx or 309xxx) there will still be some (probably unwanted) equalisation happening, so it might be best to recode your RNS-E to a linear sound characteristic (i.e. 300xxx).
See http://wiki.ross-tech.com/wiki/index.ph ... 28RNS-E%29
ROY
Post by ROY » Sat Aug 25, 2012 2:50 pm
I noticed the volume changing quite a bit on an 8 hr drive yesterday, the non res milltek was playing havoc with the system.
TrevoRS4
Post by TrevoRS4 » Sun Mar 15, 2020 3:12 am
Back from the dead.... I find it very annoying that the default volume is so high. Can anyone advise what setting needs to be changed in Engineering Mode? In the Radio TestMenu 3 I don’t see what would do the trick.
Users browsing this forum: Google [Bot] and 85 guests
