changing default volume on RNSE... help
Is there a way to change the volume of the RNSE when you first start up the car? Can it be done through vag.com? Anone know where its hidden?
RS3 8P 2013 Phantom Black with Ally Pack and Black Optics Grille | LED Interior and number plate lights - GONE
RS4 B7 2006 Phantom Black with Titan alloys and mirrors - GONE
Re: chnaging default volume... help
I'll look into that, I'm also not sure my volume is increasing as the ambient noise increases, trying to figure out how to activate that too.
'56 ST220 (Sold)
'97 ST24 (Sold - loved lots)
'56 ST220 (Sold)
Yeah this is problem for me too as I use my processor to control the volume and have to set the RNS-E volume to just below clipping point but every time I turn the ignition off then on it decides to lower the lower and I have to find the max volume point again.
no one got any advice on this?
- PetrolDave
Re: changing default volume on RNSE... help
This question got asked a lot a few years ago, but no definite answer was ever found.
For some people, me included, setting the volume on the RNS-E "Radio TestMenu 3" Engineering Mode screen worked - but that didn't seem to work for everyone.
This is annoying me too TimTimDogg wrote:I'll look into that, I'm also not sure my volume is increasing as the ambient noise increases, trying to figure out how to activate that too.
I've checked as much as I can but can't find no settings
Gone but not forgotten boohoo !!!
RS4 Sprint Blue Avant on Dyno after Carbon Clean http://youtu.be/7lsBbmmaDQc
Dave
Is your suggestion to make the volume change with ambient speed or is it to change the turn on volume?
- PetrolDave
It's about the subject of this thread - changing the default volume.MikeFish wrote:Dave
Changing the volume vs. speed setting does nothing as the Bose AudioPilot system resets that anyway.
I only asked because the second post also asked about the ambient noise issue and it was not clear from then on whether everyone was still talking about the original issue or not. Also your picture had the gala setting highlighted and I thought this was the name for the ambient noise setting.
- PetrolDave
That's a "stock" picture not one I took specifically for this thread.MikeFish wrote:Also your picture had the gala setting highlighted and I thought this was the name for the ambient noise setting.
"GALA" is a bit of a misnomer, because we have AudioPilot which isn't speed dependent volume changing - it's background noise dependent volume changing. There's a microphone in the interior light that measures interior noise, the Bose amp subtracts the "music" signal from that to get an estimate of the interior noise which it use to adjust not only the volume but also the frequency response of the Bose amp.
GALA based speed dependent volume changing did nothing when driving on rough roads, but AudioPilot increases the volume to compensate.
Ok thanks for clearing that up. So (off topic I know) if I am not using the Bose amp there is no sound level change going on (which is exactly what I want)?
Now just need to stop the volume going down every time I restart the car.
- PetrolDave
There's no change going on in the amp (As you're not using it) but if your RNS-E is coded for an A4 or Bose sound characteristic (i.e 301xxx or 309xxx) there will still be some (probably unwanted) equalisation happening, so it might be best to recode your RNS-E to a linear sound characteristic (i.e. 300xxx).MikeFish wrote:Ok thanks for clearing that up. So (off topic I know) if I am not using the Bose amp there is no sound level change going on (which is exactly what I want)?
See http://wiki.ross-tech.com/wiki/index.ph ... 28RNS-E%29
I noticed the volume changing quite a bit on an 8 hr drive yesterday, the non res milltek was playing havoc with the system.
Back from the dead.... I find it very annoying that the default volume is so high. Can anyone advise what setting needs to be changed in Engineering Mode? In the Radio TestMenu 3 I don’t see what would do the trick.
