Hi all,
I am a new RS6 owner; Purchased 2003 RS6 from a dealer - with a 3 month "comprehensive warranty" from the RAC.
A week ago I noticed a fairly low level "rubbing" noise from the drivers rear side, so took it to the local garage, after a short inspection they have diagnosed new shocks are requied - the dealer has said that they wont pay for the repair to be fixed if it falls outside the warranty? warranty only covers a broken shock rather than wear an tear??
Having looked throught the last MOT the below faults were found -
- rear shock absorber reduced damping effect
- rear gas suspension unit pipe corroded
does the dealer have any legal obligation to cover these repairs as they were known and not disclosed at point of sale?
Any help would be greatly appriciated!!
RS6 - 2 months in and problems - HELP
Re: RS6 - 2 months in and problems - HELP
Firstly - FON.lew909 wrote:Hi all,
Secondly - read through your rights on second-hand car purchases. I'm pretty sure the dealer should not have sold you the car unless these issues were disclosed, especially if the car was advertised 'in good working order'. It would be very difficult for them to argue this failure was due to wear and tear on your behalf, the MOT advisory states this issue was present before it was sold to you. You've got a fair bit of power if you act quickly.
Rule 1.
FON - brilliant!
Thanks for the above pal - I have given the dealer 48 hours to respond then will seek legal assistance! will keep you posted.
lw
lw
act swifty and assertively
the part is leaking ther for dosn't work = broken?
selling of an unroadworthy car if it was leaking in its test it should have failed did they test it thereselfs or a neerby freindly tester
Fonlew909 wrote:Hi all,
IIRC its 28 days to reject a car and if you keep driving it you muddy the water!
950 nm torque!
Ohh running bridgestones because they are the best
I had a very similar issue with mine the dealer ended up coughing up 400 quid but in hindsight I should have held out for more, but the car had been at Qst for over a month by that point and I'm going through moving house so I could really do with having the car back, if it's on the mot then the car was sold to you not fit for purpose see my old thread under 'dealer/warranty issues there's loads of helpful responses from others on there
Users browsing this forum: Google [Bot] and 9 guests
