front shock replaced, now epc and traction light on
ArthurPE
Re: front shock replaced, now epc and traction light on
Post by ArthurPE » Sun Aug 05, 2012 8:33 pm
adsgreen wrote:No I do agree that given you'd think the only thing that could be disturbed with a drc change would be a speed sensor... just not immediately matching up to the indicated lights.
The bit I find really annoying is that this is trivial to diagnose with vag com - hell, the obvious thing to do is read the logs, store them and clear the codes and see what happens.
customer service:
hook up the computer while the customer waits
read the code
see if it tells you something easily fixed, fix it if you have the part(s)
if not clear it and drive the car, if it comes back, keep it, if not perhaps just a 'glitch'
ArthurPE
Post by ArthurPE » Sun Aug 05, 2012 8:54 pm
osf?
is the left side (as travelling)?
on this wheel is a level sensor, linked to suspension and body, so if the car starts to get a weird attitude it is sensed
also used for headlight leveling in BMW's, maybe it's connected to TC?
also one on the right rear
adsgreen
Post by adsgreen » Sun Aug 05, 2012 9:09 pm
ArthurPE wrote:osf?
Off side front so in rhd cars would be the right side of the car in direction if travel.
adsgreen
Post by adsgreen » Sun Aug 05, 2012 9:10 pm
customer service:
read the code
Exactly - having a customer 1) without their car, 2) with a precious courtesy car for the sake of a quick look, scan and reset seems crazy to me.
Post by bam_bam » Sun Aug 05, 2012 9:23 pm
adsgreen wrote: If you are getting both lights I'd be thinking either a sensor or the ABS controller is screwed - does vag com shed any light or point to a particular wheel?
(BTW - love you too ;-))
VaginaCUM isn't helping, zero codes on the ABS module or any wheel speed sensors but there have been codes on varying WSS previously. Currently it's remaining inconsistent, 3 drives in 5 have the TC and ABS lit up on the dash... again, no codes left to look at.
Not the same car though.
ArthurPE
Post by ArthurPE » Sun Aug 05, 2012 10:26 pm
sometimes with metallic pads the filings/dust get magnetized and adhere to the wheel sensor (basically a proximity switch that generates pulses)
this debris will degrade their operation
try cleaning them with brake cleaner or electronic cleaner (rinse with water when done)
do the electrical connectors too with electronic cleaner
Post by bam_bam » Sun Aug 05, 2012 10:28 pm
ArthurPE wrote: try cleaning them with brake cleaner or electronic cleaner (rinse with water when done)
Will do. Cheers.
ArthurPE
Post by ArthurPE » Sun Aug 05, 2012 10:43 pm
Will do. Cheers.
while your at it look at the hub, usually some teeth or metal inserts that get counted by the sensor
hit those with a scrubby if they have any rust on them
http://autorepair.about.com/od/regularm ... ns_cln.htm
Users browsing this forum: Bing [Bot], Google Adsense [Bot], Zyox and 440 guests
