An LED number plate light that works?
Re: An LED number plate light that works?
For those happy to do some DIY electrical, see my post of ages back - can use any LED bulbs then...
http://forum.rs246.com/viewtopic.php?f= ... te#p350056
OK
put the ECS ones in
when turned on, bulb out warning!
but I had only put them in loosely to test them and one had popped out, phew
pooped it in, warning went out
tightened the screws down, checked it 1/2 dozen times, all is good....and very bright
put the ECS ones in
just got all the interior LED's in, easy, just patience and time, 18 of them iirc
since they draw less power picked up 0.001 HP
won't help though since they are only on when doors are open, etc.
cleaned all the lens with a plastic cleaner/polish along the way
they are bright, and look good, white/blue as opposed to yellowish
silly, but I like them
interesting install method!ArthurPE wrote:OK
phew pooped it in,
RS6chris! wrote:I bought these...
http://www.ebay.co.uk/itm/Audi-A4-B6-S4 ... 3370110699
Had them in my C6 RS6 now for two months....very good quality...nice crisp light...and no errors at all.
Chris.
I fitted the above today very happy with the result
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Also check out these if you want interior LEDs
http://www.ebay.co.uk/itm/280696913699? ... 1423.l2649[/quote]
I also fitted the interior kit only isssue i have it the led's for the door don't seem to work but happy that the interior all work with no errors
I got interior kits for sale with some nice custom bulbs for the boot, footwell, glove and puddles and red door warning lights.
here is some info:
Having tried several different bulbs out in this unit i found that the light spread of an "off the shelf led" was not as consistent as the stock bulb, so i set out to design a bulb that would fit in the unit where all the bulbs face down and out where they should be. i got my thinking cap on and produced a sketch of what I thought would work, then cut out bits of card and some broken led’s and stuck it altogether and found that I had just designed and made a bulb, Great I thought, but now I had to get the design’s over to the factory to see if they could make the bulb to my spec with the correct canbus specs, at 1st I was told a canbus bulb of this type could not be done, I then sent back an email saying do whatever you can to get some canbus into it so no errors come up or that it would work as I have had problems trying to get a bulb to work in the boot of an A3 as I am sure a lot of you have.
Pictures were sent back and forth and this bulb was formed….
the kit is £59 posted for uk and NI. it wont include rear footwell lights if you have them.
sunvisors
front map
front dome
rear map
front footwell
puddle lights x4
red door warning lights x4
glove
boot.
They will be on here for sale next week so keep an eye out.
Trups
here is some info:
sunvisors
front map
front dome
rear map
front footwell
puddle lights x4
glove
boot.
Trups
I will also have an offer on ice white bulbs for the number plates, these are error and are white as getting an LED to work in the B7's without DIS is hard.
Trups
Trups
just had a bulb failure ond the licence plate
to they will be out and old bulbs back in thats boring
how about my ice white bulbs this week when they go up? i will have 2 pairs for £10 posted in the UK or NI.?
Hey Trups,
I'm interested in some, will send you a message about them. I was really pleased with your kits you supplied for my last 3 cars and the xenons for my van. Good and genuine seller.
Speak soon
Speak soon
Audi B7 RS4 Avant. Custom H&R Race Coilovers. Yellow Stuff pads, Bespoke JC Wedlfab Valved Exhaust, 9x20" RS5 Rotor wheels ET26. G23 Engineering Spacers with a touch of OCD... www.Edition 38.com
Trups, if they are for the interior then there is no need for them to be error free as there are no alarms for interior bulb failures.
what about the DRL's - Thats the one people want
I agree, still looking for an error free LED DRL. The bulb Trups was working on above would fit the sidelights though.
Mike they wont show up up the DIS.
in VCDS if they aint canbus they will, also if they are not canbus they stay slightly lit.
DRL's im working on, i am waiting on the address for a member so i can post him them to test so i can get it confirmed for you guys.
The halogen ice white number plates are going to have to wait as the factory send me the wrong type.
Users browsing this forum: No registered users and 175 guests
