DRL bulb replacement....
I purchased some PIAA bulbs to replace my yellow DRL bulbs, but went to fit them this afternoon and it seems its not as easy as I thought?! Whats the best way to get to them, it seems like a right basta*d!!!
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
66 Sapphire BMW F80 M3.
18 Mythos Black RS4
14 Daytona Grey RS6
08 Monza Silver RS6 Avant
07 Phantom Black RS4 Avant
Loads of BM's inc. 4 x M's
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
There is no easy way, apart from removing the lights.
If you have hands like shovels your are off to a bad start.
Re: DRL bulb replacement....
It's not easy but possible. The more you do it the easier it becomes as you kinda know where to twist your hand and how much it hurts to do the job. Drivers side is much harder.
PS, the first time I did it I the original bulb came out before I got the holder out the back of the lamp. The more I tried to grab it the further in it went. Needless to say, it is still in there, so be careful as you remove it.
Take it there were some curse words used!MikeFish wrote:PS, the first time I did it I the original bulb came out before I got the holder out the back of the lamp. The more I tried to grab it the further in it went. Needless to say, it is still in there, so be careful as you remove it.
Yeah, I tried to hook it out with a wire coat hanger but it was no good, the damn thing is still rattling around in there.
I have done it quite a few times now as Im trying to find some LED lamps that dont give errors. I am assuming that vestax32 doesnt need help with removing bits to get access but is only having trouble with the actual bulb removal. Half the battle is knowing which way to twist the lamp holder.
It is fiddley and only acheived using the tips of your fingers, right pain.
Mikefish - Can you not fish the original bulb out using a magnet?
Now - Audi SQ5 Plus and planning future A3 3.2 DSG Turbo Project
Which way do you turn the bulb holder then?
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
Start on the drivers side as that is the easiest in terms of access... If you look at the font of the bulb holder you will see the cut-outs/shapes this will show you which way to turn it - likewise when you put it back use a torch to ensure the holder is lined up with the cut-outs as the bulbs fall out from excessive turning of the holders.
To get the bulb out I used a straightened out oat hanger with some double-sided tape on it was actually very easy to fish out or I got very lucky as thought was going to be a bumper/light off job.
i tried the coat hanger but without the double sided sticky tape. i pushed it so far in that i cant even see it now, think it has gone over to join the headlamp.
i found the drivers side much harder to to because of a radiator / air con (cant rememebr which, but pretty sure it was radiator) hose is right in the way. I tried to remove it but that seemed harder than denting my hand and forcing just enough finger in (that sounds a bit rude).
Which bulbs have you replaced them with, more "xenon" looking ones? Do they bang out errors?
Would like to do this myself but can't seem to find a decent bulb without errors? I'm not keen on the yellow OEM ones so never use my DRL's!
Current - 2017 Nardo RS5
These are the best non LED ones;
http://www.ebay.co.uk/itm/110833383119? ... 480wt_1180
I have just fitted mine and they don't throw up any warnings and look a hell of a lot better than the oem ones.......
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
That's the ones I use.vestax32 wrote:These are the best non LED ones;
Also have these as sides.
http://www.ebay.co.uk/itm/XENON-BULBS-U ... 1c0fc02e4d
I also have these as fogs
http://www.hoen-usa.com/fog.htm
These as number plate bulbs.
Höen 4,000k direct replacement incandescent 36mm
http://www.hoen-usa.com/licenseplate.htm
All bulbs so no errors and great performance so far.
Users browsing this forum: Google [Bot], Google Adsense [Bot], irishmike, Majestic-12 [Bot] and 122 guests
