Slow to change gear?
2.5 I5 20v TFSI - 335 bhp
dbm
Post by dbm » Wed Jul 18, 2012 8:47 pm
Compared to my TTS, my RS3 is really slow to respond to gear changes using the paddle or stick. Sometimes it seems to refuse to up-shift as well, typically when pulling out of a side street with a bit of extra throttle (nothing too hard, mind).
Does this sound like normal behaviour or is a trip to the dealer in order?
Dave_Hedgehog
Re: Slow to change gear?
Post by Dave_Hedgehog » Thu Jul 19, 2012 12:02 am
cold oil?
they do learn tour driving pattern and can be a bit slow when adjusting to your driving style
dbm
Post by dbm » Thu Jul 19, 2012 7:14 am
Could be cold oil as it is more pronounced when the car is cold.
I didn't think the car did any learning in +/- mode, just in D and S?
Dave_Hedgehog
Post by Dave_Hedgehog » Thu Jul 19, 2012 10:17 am
Could be the mecatronic unit, wouldn't be the first with an issue, easy fix thou
dbm
Post by dbm » Thu Jul 19, 2012 11:41 am
Yep. Guess I'll book it in...
SteveCuz
Post by SteveCuz » Thu Jul 19, 2012 4:10 pm
I'd get it looked it. My changes are very fast and responsive.
Steve
2011 Audi RS3 Daytona Grey | 2003 Audi RS6 Avant Ebony Black
dbm
Post by dbm » Thu Jul 19, 2012 4:38 pm
Thanks again, I'll definitely get it looked at.
P1RWM
Post by P1RWM » Thu Jul 19, 2012 6:14 pm
I also have some inconsistencies in the gear changes, mainly when manually changing. Car is booked in for next week for a check up
Stoo.
Post by Stoo. » Thu Jul 19, 2012 8:29 pm
There are some TPIs out with regard to TTRS/RS3 shift profiles.
Definitely get it looked at.
Could just require a software update.
funkygibbo
Post by funkygibbo » Thu Jul 19, 2012 8:45 pm
Nope, gotta say, no issues with changes either in manual or sport mode.........get it checked out!
dbm
Post by dbm » Thu Jul 26, 2012 8:02 pm
Ok, car went into the dealership today but they couldn't reproduce the problem. The master-tech checked out my car and looked for error codes on both the engine and 'box - none showed. That's ok, the problem normally happens quite predictably when the car is stone cold so it will go back to the garage next week to stay overnight and on the next morning I'll take the master-tech for a ride and see about demonstrating the problem. Luckily I'm a professional system tester so reproducing problems is an established skill for me :)
Interestingly there is a technical note against the RS3 regarding adaption and how this process can result in it feeling jerky for a period.
I'll attempt to reproduce the problem again myself in the morning and his time I'll video it - you forget that you have a HD video camera in your pocket all the time these days!
Stoo.
Post by Stoo. » Thu Jul 26, 2012 8:04 pm
Stoo. wrote:There are some TPIs out with regard to TTRS/RS3 shift profiles..
dbm wrote:Interestingly there is a technical note against the RS3 regarding adaption and how this process can result in it feeling jerky for a period.
dbm
Post by dbm » Thu Jul 26, 2012 8:51 pm
The technical note basically said "it's not a problem" - nothing to sort?
Stoo.
Post by Stoo. » Thu Jul 26, 2012 9:24 pm
Well I'll tell you this, he needs to have another look ;)
Which dealer is it?
dbm
Post by dbm » Thu Jul 26, 2012 10:42 pm
Preston. Have you got any kind of reference number I can quote?
