DRC Goodwill no more
Just spoke to my local stealer about a misting shock flagged on the MOT as this would be just before my 5 years on the car ask ths should then be replaced under the goodwill warranty only to be told that sorry sir this has now been closed since the 1st of april the service manager is off at the moment so will bring it up with him when he returns failing that Audi UK
anyone got the coustomer service number
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Re: DRC Goodwill no more
Misting would unlikely be covered anyway - got to have visible fluid leaking and that would be an MOT fail.
Specifically says in the VOSA guidelines that a misting shock is normal and not grounds for a fail.
As for the goodwill... plenty of 08 cars around that would easily have another year left...
Personally I think it's a case of finding the right dealer and being prepared to contribute. Shocks are considered wear n tear and lasting 5 years is not unreasonble in itself... most new car warranties have explicit shorter warranty periods on shocks.
neckarsulm
Anyone know the current costs of DRC work?
I must saw the APS set up KWV3 car I drove last year was superb, SS+ low and dead comfy, handled like a go kart too.
Had my one replaced last year and dealer said I have a further 5 years on the shocks don't know how true but I guess we will have to see
- PetrolDave
Just had the offside rear fail, which took out the valve block - cost of parts was £1287 (shock £173, valve block £734, braided hose £98), plus labour & VAT came to £1552. Dealer said 2 year warranty on parts - I had the fronts and the valve block replaced 2 years and 1 month ago, so the warranty on the valve block had expired by 1 monthneckarsulm wrote:Anyone know the current costs of DRC work?
Failed after I had to swerve to avoid three numpties walking in the middle of the road on the Emsworth bypass after dark.
neckarsulm
So swerving causes DRC failure?
Amazing.
Amazing.
- PetrolDave
Yep.neckarsulm wrote:So swerving causes DRC failure?
Amazing.
Had no problems at all until I had to swerve across 1 lane to avoid these numpties, within a couple of minutes I heard the classic rattling sound from all 4 corners when going over any bump. I wouldn't have minded so much if I had been going silly fast, but I was 4-up and was only doing 77mph (according to my GPS).
It'll be interesting to see how many B7s will go to coilovers as the DRC gives up...
if I have my car when the DRC gives up the ghost and I can't get Audi to fix it
Bilstein struts/shocks
new front/rear strut/shock mounts
H&R springs
everything can be had for less than $900 delivered
simple, reliable and robust
H&R springs
Ditto - drc is great but too expensive to be considered a 'consumable'
neckarsulm
Dear Mr. P. Dave,
We thank you for your letter regarding the failure of your DRC.
Unfortunately as the incident occurred at 77mph which is beyond the maximum speed limit for the country to which your car was exported, we are unable to offer any goodwill on this occasion.
Furthermore we will advising the local Polizi of your crime and you will be shot.
Stephan Reil
quattro GmbH
PS And please next time only use a lower case 'q' when contacting us
Stephan Reil
quattro GmbH
- TonyHayers
- 5th Gear
Would you rip out all of the DRC junk completely? e.g central valves etc or just leave them in empty/dry.ArthurPE wrote:if I have my car when the DRC gives up the ghost and I can't get Audi to fix it
H&R springs
06 Phantom Black Saloon:
^ GONE
^ GONE
DRC parts are relatively inexpensive to find albeit PD appears to have been stung a little on the valve block, I've seen a pair on E-bay for £130 albeit typically there are none there just now. I'd be for repaiting it first beforre ditching and would work out roughly the same as ditching it all and putting coilovers in?
But then the fear of it going wrong again over time or when you do a little swervingP_G wrote:DRC parts are relatively inexpensive to find albeit PD appears to have been stung a little on the valve block, I've seen a pair on E-bay for £130 albeit typically there are none there just now. I'd be for repaiting it first beforre ditching and would work out roughly the same as ditching it all and putting coilovers in?
- PetrolDave
Hampshire Police couldn't be arsed at 77mphneckarsulm wrote:Unfortunately as the incident occurred at 77mph which is beyond the maximum speed limit for the country to which your car was exported, we are unable to offer any goodwill on this occasion.
I take that as a personal slur since (unlike some people I could mention) I NEVER use an upper case q, except when talking about a genuine Audi Quattro - I respect what Quattro means.neckarsulm wrote:And please next time only use a lower case 'q' when contacting us
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 351 guests
